Mileage per Tank?
Old 07-04-2007 | 02:01 PM
  #46
sellisrulzz's Avatar
generally 600, right under 20 mpg. Close enough to 20 to call it 20. And thats with 315's, and a truck that weighs over 7K lbs... cant beat it.
5 speed, and i dont hot rod it. its a truck. if i want a hot rod, i jump in the wifes charger.
dont the 5 & 6 speeds have the same final gear? OD?
Old 07-04-2007 | 02:16 PM
  #47
DieselAvenger's Avatar
Originally Posted by moterhead
The best I've ever gotten was 835 on one tank. I do have Dave Kelley's tank vent kit which allows you to COMPLETELY fill your tank. Put 37 gallons into my "supposed" 34 gallon tank. That's 22.5 mpg. I regularly get 22 to 23 per the overhead. Whenever I hand calculate my mpg, I get about 1 mpg better than the overhead is showing. MOst claim the overhead shows higher. Mine shows lower.
Is that mainly highway mileage?
I have a 50/50 mix on highway / city. Most of the roads down here are 45 and that hurts my trans temps and MPG. I need to stick a lockup switch in.
I'll be heading up to NH at the end of the month, so I'll see what I get at 70-75 all highway mileage.
My truck is doing better after getting the PCM updated and speedometer calibrated. Im at 310 miles just a hair below the 3/8 mark. That used to be below the quarter mark.
Old 07-04-2007 | 02:41 PM
  #48
moterhead's Avatar
Yes, that was on a trip from my (then) home in the Florida Keys to Sturgis. The 835 leg was from Columbia, Mo to Rapid City. I got off I90 at exit 61 and filled up at the Flyin' J. That's when I put in the 37+ gallons. I was not towing, but had my '99 Harley dresser in the bed of the truck. Also, I had a 5 gallon can of diesel with me in case I ran out. Yeah, I know it's bad on lift pumps, etc to run 'em out, or even that low. Must not have hurt it. That was the summer of '04 & it's still going strong.
Old 07-04-2007 | 09:35 PM
  #49
Sevir's Avatar
i easily get 22-24MPG on highway and 19ish in town. I just made a trip from Tennessee to Washington state and got 14.2MPG towing a 10k enclosed trailer. other then my mods, i have stock 265 tires and 3.73 gears.
Old 07-07-2007 | 12:28 AM
  #50
gus's 03's Avatar
UPDATE..
3 consecutive back to back tanks over 850 miles, and toped off tank after clutch job.. thats almost 4 complete back to back tanks over 25 mpg!
70% stop & go, 20% highway@ 70+mph, 10% play
Old 07-07-2007 | 01:04 AM
  #51
streetsmoker's Avatar
Without doing any racing. Allways over 800mi. to a tank. Once, even got 887mi. Average about 22-23mpg+. Here was my thread on the 1st time attempting to max my fuel mileage and the testing data: https://www.dieseltruckresource.com/...=800+mile+club
Old 07-08-2007 | 02:32 PM
  #52
bp76126's Avatar
I get 18-19 around town for a commute and a little over 21 mpg on a recent trip to New Mexico (70-80mph). Only 3700 miles on the clock so it'll get better! 06, quad cab, auto, 2wd.
My little V6 Sonoma gets the same mileage with half the weight and 1/3 the torque, got to love the Cummins
Old 07-08-2007 | 03:34 PM
  #53
notblowingsmoke's Avatar
650 mpg - 850 mpg... It all depends on the performance settings that I am running and how heavy of a foot I feel like having.
Old 07-09-2007 | 08:24 AM
  #54
JohnInNH's Avatar
WOW!!!
That's some crazy MPG
Maybe it's MPT (miles per TANK)
650-850 MPG ?
Old 07-09-2007 | 08:45 AM
  #55
Speed Shift's Avatar
WOW I only get about 500 mpt, and I thought that was pretty good, but I have never really taken it to the limit....
My truck is also a dually 4dr 4x4 G56 6speed lifted with 285/70s
Old 07-09-2007 | 09:02 AM
  #56
wow... seems like those with the best mileage have a programmer, and mods!!!!
Old 07-09-2007 | 09:12 AM
  #57
donnee's Avatar
Every time I fill up, the overhead shows in the neighborhood of 650 miles DTE.
The last tank showed I got 22.6 and hand calc was more in the neighborhood of 18-19.
This is a combo of city and hiway @ 70
Only change is a Amsoil dropin and MBRP.
It may not be the best but Im happy with it being the truck is as heavy as it is.
Old 07-09-2007 | 09:43 AM
  #58
wow... 650? Most ive ever seen is 490.
Old 07-09-2007 | 10:04 AM
  #59
Originally Posted by JohnInNH
WOW!!!
650-850 MPG ?
I ment MPT...
Pretty sleepy yesterday
Old 07-09-2007 | 08:43 PM
  #60
joe22790's Avatar
I just checked mine today and I got 14.75 MPG and 400 MPT hand calculated. I run between 75-80 mostly open road here in Texas. Its very flat but the winds are very bad. I am taking mine in for a reflash tomorrow. I will let you know if it helps.
Quick Reply: Mileage per Tank?
