Mileage per Tank?
Old 06-15-2007 | 07:29 AM
DieselAvenger's Avatar
Mileage per Tank?
What kind of mileage are you guys getting per tank?
Im getting 407 - 458 per tank on an 04.5 with a leveling kit... with an average MPG of 14.77, averages after 6 fillups, and a 1.087 correction factor due to 315's.
This is a bit low from what I read on the forums... from what I understand the dealer has some flashes they can do, correct?
Old 06-15-2007 | 07:53 AM
blackmajik's Avatar
I am getting around 17.5 to 19 mpg. 2 inch lift and 315's. Make sure that you change your fuel filter every time you change your oil. That should help.
Old 06-15-2007 | 08:57 AM
Gumby's Avatar
Geez, that's pathetic mileage! What gears are you running? I normally get 600+ miles to a tank & average 19.5 to 20 driving back & forth to work at 70 mph.
Old 06-15-2007 | 09:13 AM
soulezoo's Avatar
DTR 1st Sergeant
This morning, my tank is sitting at a little over 1/4. I have 542 miles on the odometer. I can get 650+ easy-- 700 driving like granny.
Old 06-15-2007 | 09:17 AM
Stock gearing, i believe they are 3.73's.
Old 06-15-2007 | 09:18 AM
levigarrett76's Avatar
i usually get 500-550 with my 07 QC DRW 6spd 4x4
Old 06-15-2007 | 09:26 AM
SolarExpress's Avatar
As high as 800, as low as 650, but I have a 6spd.
Old 06-15-2007 | 10:15 AM
dodgezilla04's Avatar
i always get at least 600 miles to a tank.
geez. i get over 400 when towing my 10k trailer.
Old 06-15-2007 | 10:55 AM
lamadera's Avatar
Last week I got well over 400 miles to a tank hauling my slide-in camper at 65-70 MPH. The leveling kit and big tires will really hurt your mileage. Dealer flashes won't do much except make the overhead read higher mileage. If you are serious about good MPG ditch the leveling kit and tires.
Old 06-15-2007 | 11:00 AM
Truckman0097's Avatar
I get between 500 - 600 stock with automatic. I have not actually hit 600 yet because I haven't done enough highway driving on one tank with no load. I got almost 500 (460-480 range) pulling a 16 foot enclosed trailer from Ohio to Eastern PA last weekend.
Old 06-15-2007 | 11:04 AM
md-rebel's Avatar
600-650 when light comes on, runnin 65'ish on I-95 commute.
Old 06-15-2007 | 02:48 PM
Snopczynski's Avatar
486 miles before filling, equates by hand to 15.005 mpg on the tank with 2007 5.9L ctd with 4k miles on it.
Old 06-15-2007 | 04:11 PM
robertc82's Avatar
I get 420 to 450 driving 60 70 or whatever, but with my oversized tires and my speedometer wrong isnt my odometer wrong to?
Old 06-15-2007 | 04:38 PM
Yes... if tires are oversized you are going further... (( tire height x profile x 2 ) / 25.4) + rim size (for inches) for your tire... or you can measure the height and get an actual number.
Stock 265 tire should be ~31.606299 inches tall.
My 315 is ~34.362205 inches tall.
I have a ratio of 1.087:1 for mileage / mpg.
Whatever the speedo reads, i multiply it by 1.087 and that is the actual.
So for your 305's, you have a ratio of 1.069:1
Old 06-15-2007 | 05:05 PM
rockcrawler304's Avatar
650 - 675 to a tank. 80% highway (70-75mph) and 20% city. I also have the 6spd.
Quick Reply: Mileage per Tank?
