Maybe a stupid pipe question, but.........
Old 09-15-2004 | 06:36 AM
Big Rig's Avatar
I'm trying to change the pipes on the 600. The factory exhaust is clamped together with ubolt connectors. The ubolts have crimped the pipes together and I can't seperate each section.
Other than cutting the factory pipe, does anyone have a suggestion to get them apart.
PS I've already tried a sledge hammer!!!!!!!!
Old 09-15-2004 | 08:41 AM
SuperGewl's Avatar
Re: Maybe a stupid pipe question, but.........
Try a BIGGER Freggin Hammer
Old 09-15-2004 | 08:50 AM
DPG's Avatar
DPG
How about heat?
Old 09-15-2004 | 08:53 AM
DF5152's Avatar
use a torch get them cherry red and they will come off also if u have the tool to resize the ends do it while it is hot
Old 09-15-2004 | 11:25 AM
gsdog1's Avatar
Saw-z-alls and torches dude!! That's part of the fun!
Matt
Old 09-15-2004 | 11:28 AM
BigBlue's Avatar
Either get a bigger hammer or cut that puppy off. You won't be needing it anymore.
Old 09-15-2004 | 11:55 AM
nickleinonen's Avatar
cut off wheel on a grinder and slit the pipe in 2 spots where the crimp is [slit them perpundicular [sp?] to the crimp] and then start twisting, the pipe should expand a bit and come off [sawzall is quicker...]
Old 09-15-2004 | 12:46 PM
Big Rig's Avatar
Thanks for your imput.
This may sound wierd, but I'm trying to keep the oem pipes in tact, in case I need to replace them. ie Warranty and CAT issues and/or emmission test (not yet required in Knoxville TN).
SO... if at all possible, i'd like to gently remove it, with the option to replace if needed (HOPE NOT)
Old 09-15-2004 | 05:04 PM
Dodgezilla's Avatar
Good luck! I did mine at around 10,000 miles and ended up having to cut it all off. It doesn't take long for the rust to set in.....
Jim Lane
03-23-2013 09:31 PM
blackdiesel
01-13-2006 10:19 PM
deezulsmoke
Competition / Pulls / OffRoad
09-16-2005 06:20 AM
Hoss
05-19-2005 02:28 PM
JKM
03-22-2005 06:29 AM
Quick Reply: Maybe a stupid pipe question, but.........
