Max continuous RPM for an 06
Old 07-04-2007, 07:19 AM
bcfitzsimons's Avatar
Hey everyone what's the highest continuous RPMs for driving without doing any damage to an 06 CTD? I know redline's 3100, but do people limit their revs to 2900 or lower for cruising while towing? I just don't want my engine to self destruct
Thanks!
Old 07-04-2007, 07:36 AM
Hairy1's Avatar
Location: Adirondacks of New York and Daytona Beach FL.
Arrow Shift
Sounds like you need to shift up?
What are you running in to maintain 2900 rpm?
Old 07-04-2007, 07:37 AM
oilfield-trash's Avatar
Thanks!
You can run your truck all day at redline. Thats why its there. I usually run 70-75 hours on end with the cruise. 22-2300 +-.
It won't hurt a thing.
Old 07-04-2007, 08:15 AM
Thanks for the info-
Hairy I wasn't running in anything specific I just wanted to know what people thought that's all-
Thanks for the replies though
Old 07-04-2007, 09:04 AM
Jeff in TD's Avatar
Torque drops off pretty steep above 2700, so although it won't hurt it to run it higher, doing so would likely just burn more fuel...
I inquired from Cummins what the proper RPM range is with the ISB, and I'll just paste in what they said...
In the Dodge application, the rpm of the advertised or maximum rated power of the engine is 2500 rpm (prior to 1996 models), 2600 for 1996 and newer models with 12-valve manual transmission and 2700 rpm for 24-valve. Peak torque is reached at 1600 rpm on all models. The Maximum Full-Load Governed Speed is 2800 rpm for 12 valve and 3200 for the 24-valve. The Maximum No-Load Governed Speed is 2950-to-3300 rpm (3500 for 24-valve).
Therefore, your normal operating range for the engine is between 1600 (peak torque) and rated rpm (2500-to-2700, depending on your model). These engines should not exceed 2800 or 3200 rpm downhill (depending on model year), under load, since that is the governed speed of the engine. At no load (i.e., if you were to push the accelerator to the floor and hold it, sitting still in neutral), the no-load governed rpm is about 10 percent over the full-load governed rpm.
The engine is designed for maximum torque or twisting power at lower RPM (1600 rpm), for hard pulls on long grades. The torque curve of the engine is nearly flat from peak torque (1600 rpm) to rated power (2500-to-2700 rpm), however, torque does drop off slightly near the rated power rpm. Typically, the 'sweet spot' rpm for cruising would be about midway between peak torque and rated engine rpm, however, any rpm between peak torque (1600 rpm) and rated speed is fine and will not harm the engine. Overspeeding above rated speed and lugging the engine under load below peak torque is not recommended.
Also we mention that on downhill operation, the weight of the truck and any load you have on it, or towing, will cause the rpm to exceed governed rpm. Even though the engine is governed while under power, the load can push the engine beyond its rated speed. We would not recommend going too much over the no-load governed rpm or you could cause valve/piston contact, which can cause major engine damage.
Any rpm between peak torque (1600) and full-load governed rpm is acceptable and will not harm the engine. However, if you are concerned about fuel mileage and long engine life, then the lower rpm is recommended. At higher rpm's, the engine uses more fuel and all internal components turn faster and wear out quicker, which will shorten the life of your engine. There is less horsepower and torque at maximum rpm and the only reason to run the engine at maximum rpm would be for higher road speeds.
For the best fuel mileage, Cummins engines should be operated between peak torque and rated speed. Do not lug the engine when running in this RPM range. What is "lugging"? Lugging the engine is when, at cruising speed, the engine is accelerated and it will not increase the vehicle speed. Also, lugging is operating the engine, under full load, below peak torque rpm.
We do not have information about shifting into or out of overdrive in the Dodge application, since Dodge designs and supplies the transmissions for their products.
If your engine is still within the Dodge warranty period or you need information about the Dodge Ram truck, please feel free to use the Dodge dealer locator or contact Dodge: (http://www.4adodge.com/frameset_main.html?dealers/index) on the Dodge website (http://www.4adodge.com/).
We thank you for your interest in Cummins products. Please let us know if you need assistance in locating the nearest Cummins-authorized Dealer or Distributor Service Provider. For assistance in locating a Service Provider, feel free to use Cummins North America Dealer Locator, which can be found on Cummins website:
http://www.cummins.com/service_locator/index.cfm
Please let us know if you have other questions and if away from your computer or have a time-critical request that needs more urgent attention, feel free to call us toll-free (from North America) at 1-800-DIESELS (343-7357). Customers may also call Cummins switchboard 1-812-377-5000 (worldwide toll call) and ask for the "800-DIESELS Call Center" for assistance.
Email direct: powermaster@cummins.com
Old 07-06-2007, 10:32 AM
TAS05CTD610's Avatar
How in the world do you run 70-75 hours on end??? That's like driving your truck for 3 days straight. You gota get some sleep in there some where?
And although 2200 to 2300 is a sweet spot, I think running it at 3,000 rpm with a load is different. The engine is designed for it, and will take it, however I would change the oil more (as you will have more continus high pressure) than normal, but they can take it. Boat motors are a good example of engines that use all there power all the time and always turn high rpms in general.
Old 07-06-2007, 01:19 PM
DBLR's Avatar
I think he may have wanted to say 70-75 MPH for hours on end not 70-75 hours.
Old 07-06-2007, 01:21 PM
wreedCTD's Avatar
that is awesome how informative Cummins replies are.
Old 07-06-2007, 01:34 PM
DECEPTiON21's Avatar
what he said
Old 07-06-2007, 03:35 PM
carharttfarmer's Avatar
cant hurt it the 5.9 in our hesston swather turns 2600 with a full load of hydalics on it all day long
Old 07-06-2007, 05:08 PM
DTR 1st Sergeant
soulezoo's Avatar
On another site a cummins engineer said the engine was designed to be able to withstand a little over 4000 rpm before it would fly apart... but don't anyone try to get it there!!!
Old 07-06-2007, 06:53 PM
53 willys's Avatar
Thanks!
you must have a G56???
me too .... you will be fine running at that high of a RPM for extended times..diesels love constant rpm and that is with in range so don't sweat it.
Old 07-06-2007, 08:21 PM
NikeTyler91's Avatar
Ive driven fer a couple of minutes at 3000rpms but the temp seems to raise pretty fast so i stop at about 210 Farenheit. After a couple minutes of that i resume normal driving. 3000 is stock set max
Old 07-06-2007, 10:37 PM
DiEseLjunKy's Avatar
I think their sweetspot estimate is a little high. On my truck anything over 2000 rpms just burns fuel like crazy. I get the best economy at about 1900 rpms.
Old 07-10-2007, 07:56 PM
el jefe's Avatar
I did 2800-2900 for about twenty minutes on a trip back from east Texas Sunday morning. It did run kinda hot, but it wasn't much more than when I pulled my brothers 4k camper. Don't know what would happen if you were actually pulling something as far as temps go, but the truck seems fine.
Quick Reply: Max continuous RPM for an 06
