Mag-Hytec trans pans
Old 05-13-2007, 07:51 AM
Turbobob's Avatar
Originally Posted by Luvnacumns
I wish... I paid around $275 for the rear and $300 for the tranny!!
OUCH!! I've looked around and found both the DD trans pan & the rear diff cover for about 260 bucks each. I'm gonna get the tranny pan first.
Old 05-13-2007, 11:48 AM
Luvnacumns's Avatar
Yeah I found them cheaper too but then I'd had to pay shipping!! If I can do anything without shipping I am much happier!!!
Old 05-13-2007, 02:27 PM
Highway 4x4's Avatar
Oh crud, I better take off my DD and put one on that holds 4 qts less than stock so the oil will cool quicker. Sure.
Old 05-13-2007, 03:29 PM
A_Manke's Avatar
I can see his point but you are making more cooling surface area to cool down the fuild. To me its like going to a two core rad to four core it does add more coolent but more area. I am sure there is sum math involved two figure it all out, but I am pretty sure the manufacture of the pans did their home work on there pans, same with a rad or tranny cooler manufacture.
2003 qcab 2wd sbox full gauges no cat paid for and mostly stock
Old 05-13-2007, 06:55 PM
rjm022's Avatar
i have the pml tranny pan which holds two extra quarts. i saw a drop in temps of 10 degrees.
Old 05-13-2007, 08:58 PM
lehall's Avatar
I found
The DD on ebay for $278 to your door.Anyone found better ?
Old 05-13-2007, 09:26 PM
TonyB's Avatar
Yes it dropped my temps 12-15 degrees and hauling huge loads I can't get over 170!!
Where is your temp sensor located? In the hot line, the pan, or ????
I have mine in the hot cooler line, leading up to the coolers.
Tony
Old 05-13-2007, 10:48 PM
Luvnacumns's Avatar
Tony
One is in the Mag Pan Port and the other is in the tranny test hole port..
Shane
Old 05-14-2007, 03:39 AM
bpdp379's Avatar
Here is the place I got mine:
http://www.gautoparts.com/product_p/mag-727-dd.htm
$258 shipped.
Old 05-14-2007, 07:20 AM
samfox737's Avatar
Has anyone compared ground clearance on the 2wd, pulling my 27' fifth wheel from a stop trans temps stills gets up to 210-215. I need to get my temps down to help the protect transmission.
Old 05-14-2007, 09:41 AM
TonyB's Avatar
Shane
So what are the two temps, when towing & empty? Just trying to get a comparison.
TIA
Tony
gscmiller
08-16-2007 05:21 PM
redhornet
07-22-2007 09:46 PM
texasram2500
05-21-2007 08:01 AM
Dodgezilla
05-24-2006 09:00 PM
Johnny
04-15-2004 02:10 PM
Quick Reply: Mag-Hytec trans pans
