Lubricate front drive shaft fitting?
Old 03-27-2007 | 12:14 AM
CampingMan's Avatar
Found a type of pointed nipple at our Canadian Tire store to adapt to my grease gun and greased the driveshaft the other day. Seemed to work well as I heard some poping as the grease was working its way through. The fitting was just long enough for it to get in there.
Did the Tie rods as well and noticed a little water getting forced out . The way it has rained here this winter im sure it was needed.
Old 03-27-2007 | 08:28 PM
FlaCracker's Avatar
I feel ypur pain! I got the Napa# 715-1213 needle, still no good! All my grease ended up on the outside. I am going to try taking a long needle and see if I can push in the valve ball, I think it just might needing freeing up!
Old 03-27-2007 | 08:44 PM
berok's Avatar
Originally Posted by TAS05CTD610
There very hard to spot. mine has grease on it, or you'd see the little hole. It's not a standard grease zerk, it's just a depression with a tiny ball and hole. You will need a needle fitting (but not the real sharp type) to put grease in it. There's somebody on here witha better picture than mine, but it gives you a general idea.
the picture is me laying on the graound, head at oil pan, feet at rear drive shaft, looking at the front drive shaft.
In the aircraft world these are called "high pressure zerk fittings", the male ones are low press.
Old 03-28-2007 | 02:24 PM
HOV's Avatar
HOV
I bought this one from NAPA: 715-1215, and it looks like this
Others on that board say it works, but it hasn't worked for me yet. The needle definitely isn't the best, because it just bends and get's screwed up prety fast.
Old 04-25-2007 | 02:41 AM
95ram's Avatar
I think most like the 715-1213 because it's longer.
Old 04-25-2007 | 06:31 AM
Hvytrkmech's Avatar
I use the thin longer needle one, I have several different size needle fittings from years of collecting tools, but after trying different sizes the one I stated works best for me because it fits better off angle, however you still get some grease pushing back out at you.
TucsonDiesel
10-29-2014 10:24 PM
local601
68
06-28-2012 04:38 PM
psj12
18
06-11-2010 05:11 AM
DZLROKET
22
07-28-2008 11:05 AM
Thenewguy
08-09-2006 02:27 PM
Quick Reply: Lubricate front drive shaft fitting?
