Lowering a 2WD 2006 QC?
hey guys I am trying to drop the back of my 4dr QC a few inches and not lose any payload capacity or towing ability. It just sits WAY up in the back and I cant stand it. I saw a thread on here a while back about some shackle brackets that were shorter, from a place in AZ. I cannot find the thread and was curious to know if anyone had a simple solution to dropping the back a few inches. Thanks, Troy
in the back there are two spacer blocks under your leaf springs. If you take those out and put them above your springs you can retain stock u-bolts and drop truck 2 inches in rear. There is a thread on it in the RV towing section on it where 5th wheel haulers drop rear because sits two high to load 5th wheel up. Did this to my 2500 2wd and have no problems yet.
I tried using short shackles on my 04, 2 wheel drive, but I have rear air bags, and the shackles won't work with air bags, I ending up selling them to someone with the same truck as mine and they dropped rear of his truck 2 inches. He's where I got them.Hope this helps.
http://www.truckn-store.com/product_list.asp?id=1889
Gaetz
19
05-14-2020 07:22 PM
nasty01cummims
06-30-2009 01:52 PM
Mike4122KSA
11-08-2006 08:46 PM
ppsi
32
05-15-2004 02:19 PM
