low speed shudder noise from rearend while braking, almost at a complete stop
So I have a 2004 2500 4x4 and i have recently noticed a shudder noise while braking and almost at a complete stop, Checked u-joint and it looks tight, thinkin it might be a brake pad, or brake disc trouble. While braking at a higher speed no noise but noise starts when truck is just about stopped, almost like a warped brake disc or something. Any one had similar troubles or noises, any info would be appreciated, thanks
Troy
Troy
mine is making a similar noise which i think is from a rear seal leaking gear oil onto the rear disc. i have not spent much time trying to figure out exactly what is going on, just thought i would give you some ideas.
Generally a warped rotor will cause the steering wheel to shimmy during braking. I would check brakes first then possibly the hub next.
Troy
Troy
reaves11
05-19-2010 08:14 PM
smallwwb
02-11-2009 08:28 AM
FiverBob
24
08-11-2003 01:46 PM
