Low rail pressure?
Old 12-28-2010 | 09:55 AM
lastcall190's Avatar
Low rail pressure?
Hopefully someone might have some ideas... I tested my PRV using the appropriate special fitting and it passed at idle. So I was going to leave the hose routed into a container and slowly raise the RPMs and thusly RP at idle and see if I got anything out of the valve. However once I started to raise the revs to 1k, hold it, 1.5k, hold it, 2k, etc, the rail pressure didn't jump up to near where I thought it should be (I believe it's not where it should be because I got some readings from other users with stock CP3 and stock programming, and comparing the two they aren't even close...). The truck starts well, drives fine, I get good MPG all things considered (winter fuel, decent amount of idling, and mostly city driving), but at 2k RPM in 6th gear I'm reading only 7500 on the RP gauge while on the highway. I have the test fitting for the injector return rate, and was probably going to check torque on the crossover tubes as well as shake the FCA. Truck has Smarty JR on SW1, Raptor100, and a 2micron filter. PSI at the CP3 inlet is ~14#. Any suggestions? No codes, no smoke, not making oil... Thanks
-J
Old 12-28-2010 | 12:27 PM
cbrahs's Avatar
what rail gauge you running? could be a bad sending unit for your gauge.
Old 12-28-2010 | 12:28 PM
Gauge is an Isspro EV2. Probably should have mentioned that, my mistake.
-J
5.9Excursion
03-13-2008 10:56 AM
dieselfite
17
10-02-2007 07:41 AM
danshsss
07-06-2007 02:47 AM
judge88
Competition / Pulls / OffRoad
02-04-2006 08:35 PM
big red psd cc
12-19-2005 11:26 PM
Quick Reply: Low rail pressure?
