Low Oil Presure ?
Low Oil Presure ?
Is this normal: when starting, and at idle my oil presure reads below 40 and just above the first black line if not right on the line. When Im driving down the road it reads normal. Is this ok?
are you using an external oil pressure gauge, or the one in the dash?
the one in the dash is just an idoit light that moves... there is no lube oil pressure sensor on the engine... there is a 6psi lube oil pressure switch.. below 6psi then gauge reads 0psi, above 6psi, the gauge reads what the ecm wants to show...
Originally posted by cincydiesel
one on the dash
one on the dash
Greguw
14
04-20-2007 04:30 PM
truk
44
01-31-2007 12:01 PM
