Lots Black Smoke, Sticking High RPMs
Hi Everyone,
This is my first post, but hopefully I can get some good responses. I have read most of the existing threads, but have not come across any that are "identical" to my situation. First let me explain. I am not a mechanic, but very mechanically inclined (thanks to poverty,ha ha ha) and usually capable.
Here we go......... 2004 5.9L cummins dodge 2500....I was on my way to work one morning, when I passed another vehicle and let off of the pedal, I noticed the engine did not respond and just kept on going as if I never let off. It did this the next 10 miles to work. Bellowing black smoke (too much fuel?) and "sticking" throttle speed. I parked it for a little while, but when I tried to start it back up, it has to turn over several times before it will start. Idles okay, but if i give it a little fuel, It stays ramped up for 10 seconds or so and then idles back down. A maaaaannn does it smoke when I push the pedal!!! Don't want to drive it like this.
Have had a Bullydog on it 6 months for economy setting only!(sure helped out) It never once seen performance settings. When it started acting up, I took the program off, and it didn't change a thing. I have also checked lift pump, replaced EFA, checked fuel filter, air etc....
Please if any ideas, I would greatly appreciate it.
when rpm's hang and then come back down it is usually attributed to rail pressure NOT coming back down. a corrupt program(leftover), or sticking fca.
if you had a rail gauge, you would see the pressure staying at the cruising pressure, and not come down with throttle position or load..
XLR8ER
0
05-03-2015 09:05 AM
jschintgen
12-31-2009 11:17 PM
JThiessen
11-26-2009 03:03 PM
StevenB05
07-05-2005 11:17 AM
