Lost lower radiator hose clamp
Has anyone ever heard of the lower radiator hose clamp breaking apart? I red- lined my temp gauge today for a few seconds and had to add about a gallon of water to limp into a dealer. They found a broken clamp. The truck only has 2500 miles on it.
I haven't heard of any others with this problem, and I regularly watch a couple of forums. I'll be sure to check mine though, thanks for the heads up and good luck.
I broke one on the 06 during test drive. I saw it was leaking when I got back to the dealer and they put a screw type on to fix it. It was the top hose clamp at the engine (head). Spring clamp steel made in China I guess??
DTR's 'Go to Guy'
I've seen 2 chebys do that on the lower hose. Kinda a cheesy clamp that locks open to install, and the line workers have to release it after putting the hose on. At first I thought they hadn't released it, but after trying to put a pair of the special pliers on it, half of the clamp fell to the gound. Agreed - screw type hose clamp was the fix for those too!
No problem with radiator clamps but had a turbo clamp (exhaust side) break which resulted in a lot of noise and a replacement turbo (warranty).
jesussaves
10-27-2010 08:59 PM
pquevill
11-18-2008 07:38 PM
Bad Ramer Jamer
12-27-2007 09:32 AM
Roperteacher
07-31-2007 11:06 PM
