Looking for part numbers
Just got back from the dealer to get my free oil change (first 4 are FREE) ;D ;D<br>The dealer got ready to do it and I was in parts to pick up a oil filter to keep in<br>the truck and they gave me the old type.<br>They then told me that was the part number it called for and I told them to<br>look up the # 05083285AA and they ask where I got it from DTR!!!! ;D ;D<br>After a call to Dodge they said that is the new number and none in stock!! ??? ???<br>So now I need to go back later to get it done!! <br>So ??? ???<br>What I ask is anyone with part numbers let me have them please!!<br>They would not sell me any Fluids as they were not sure of the correct numbers.<br>Dodge part numbers and weight Only (no brand war)<br>motor oil 15w40 Part number ?<br>front and rear Gear oil 80-90 Part number ?<br>6 speed trans oil ? Part number ?<br>brake fluid ? Part number ?<br>power steer ? Part number ?<br>Transfer case ? Part number ?<br>antifreeze ? Part number ?<br>Air filter Part number ?<br>fuel filter Part number ? (Are they really $ 50 )<br><br>I showed them the owners manual and was told that there are different look up numbers<br><br> <br>Thanks <br>Jon
Re:Looking for part numbers
Hey, we have similar taste in trucks (see sig)
I can help with a few:
[quote author=MR. GADGET link=board=20;threadid=14264;start=0#134052 date=1051826839]
Can't answer your specific question here, but I can assure you that Dodge does not "make" oil. Your engine was shipped from Cummins with Valvoline Premium Blue 15W-40 in the crankcase. In reality, any oil certified to CI-4 within the recomended weights will work. Also, you have no idea how boring this forum can be without a weekly oil war. ;D
Anything certified to GL-5 will work, I used Mobile One 75W-90
I can help you here it is 04874464 and don't be discouraged because the bottle says that it is specially formulated for the NV-3500 transmission, it is the correct stuff for the NV-5600.
Don't know.
Don't know for sure, but I would bet my life that it is ATF+4 see transfer case below for part number.
The part # is 05013457AA (its ATF+4 auto trans fluid)
Don't know.
AF53032700AA
They are only $ 50 if you buy them from the Dodge dealer. If there is a Cummins dealer in your area they are about ten to twelve bucks and the Fleetguard part # is FS19579
BTW the oil filters are also cheaper from the Cummins dealer Fleetguard part # LF16035[/quote]
Good Luck
Don't know.
Don't know.
AF53032700AA
Good Luck
nvr-enuf
07-15-2013 01:14 PM
rteig
12-18-2012 05:28 PM
sCreamin400
11-02-2008 01:46 PM
