longer crank time
hey man..........my truck started doing this 6monthes ago it goes along with my injector problem l beleave
happends When warm with my cummins
take 3-4seconds blows smoke runs normal but bit fat.
to be honest l'm turning a blind eye to it becasue my current repair bill is 2Grand!!! l dont wana know how much the injectors are gona cost l got one step higher then the RV injectors
you will need miller tool 9012 to seperate the pump return from injector return on the back of the filter housing unless you take the fitting off the back of the head and make your own tool/hose. start the truck up warm, and let idle for one minute the amount from the injectors should not be over 180 mL.hope this helps
routerguy99
18
06-30-2003 02:23 PM
