Long Cranking
Every time my truck starts with the long cranking the end result after 3 trips to the dealer is always 1 or 2 bad injectors. Always runs completely normal other than the long crank time......
Bad Voltage?
Just some food for thought here, but about a year ago my wife says "honey the truck is starting funny, it seems to be mis-starting". And it did seem to start a little funny, but I thought it was fine and she was just a bit ! However over the next year it kept getting worse and even some times it would not start on the first turn. I started to worry! One morning I woke up and she was dead (the truck not the wife), my batteries had just pooped out over night. I went and bought two brand new very pricey batteries installed them and noticed a huge difference when I fired her back up. The truck cracked right off and has continued to do so since. It even shifts more firm. I truly believe that one of my batteries had gone bad and was effecting the whole truck and how it operated. Voltages do play havoc on things that need good voltage to run and operate correctly. So who is the dummy now?
Long Cranking
Thank you nascarcamper,evan528 and notblowingsmoke.I changed the batteries,still cranks longer than normal before she starts.I'm going to call a place in jersey that only works on diesels. Thanks again for the replys.
ScotS
06-05-2008 03:04 AM
DL1221
07-14-2006 08:43 AM
