limp mode?
limp mode?
do the 03's have a limp mode setup? After working the truck real hard plowing snow i pulled out of the lot and it shifted into overdrive at 30mph. Stayed there for about 2 miles then worked fine, happened twice now. Only would kick down if over half throttle then as soon as i let up the pedal right back to overdrive.
If you haven't had the dealer recalibrate for the larger tires you need to, the info you need to give them is 601 rpm's (revolutions per mile) only a dealer can do it with there DRB tool, takes 2 minutes.
The only limp mode I know about is that the OD will drop out if the tranny fluid gets too hot. When it cools back down, then you can engage OD again.
With yours going into OD at 30 MPH I wonder if some wiring got wet from your snow plowing?
Man if that is the case I would get that fluid changed, cheap insurance, in my 01.5 I changed it every 10000 miles, but still as I suggested with the 601 rpms your tranny is thinking it running a higher gear. Its a must do.
Check the colour of the fluid, if it needs to be replaced HAVE THEM ONLY DO A FLUSH not a drain and fill. Flush gets 96% out, A drain you are lucky to get 70%.
Good Luck
Good Luck
Bobcat698
13
08-18-2006 01:20 PM
tj97dodge
01-14-2006 01:55 PM
