Limited Slip Rear Differential?
Hey all...how can i tell if i have it on my truck or not (no, i don't have the sticker in the glove box) without taking of the diff cover??? Thx
Correct me if I am wrong, but that should be fairly easy.
1. Jack up your rear end, spin one wheel. If only one wheel spins, you have a limited slip.
2. Try and spin your wheels in dirt or wet grass. You should leave 2 wheel marks, if you have a limited slip.
Derek
When you say "leave 2 wheel marks" you mean both sides spinning, correct? If so, I have always heard that described as positive traction...or a locking rear differential...if it was limited slip, the side that starts spinning should stop and the opposite side start spinning instead to try and gain traction...I may be wrong, but that's what I have always believed?
Derek
Derek
A limited slip and a postraction are the same thing. Read all about how diffs work here.
http://auto.howstuffworks.com/differential.htm
The other wheel should spin in the same direction, if its a limited slip. If its an open differential, one wheel will spin in the opposite direction. Anybody else feel free to pipe in, if I am wrong.
You can remove the cover. The TracRite has pinion gears that appear to have ground through to the outside of the case.
Do a search, lots of threads of the pros and cons of this differential.
Call AAM with the sku# or bar code# off the axle. Thats what I did & learned a little bit about the limited slip (torque biassing).I have an open rear end & can spin both tires in grass & snow if I'm sitting level with no weight on the truck.ARB might be on the market by spring.
Mine acts like an open diff when the rear axle is up on stands but when I drive the front end up on ramps the rear tires leave identical marks on the cement, if they slip. I'm guessing it has some sort of LS control. Is that the tq. biasing? It sure has a strange looking carrier and spiders inside. They don't look like spider gears at all. The gears I can see are parallel with the axles. I never saw a diff like that! The glovebox tag doesn't show anything about LSD. Craig
Actually...the service guy pulled up my vin on the pc....he couldn't read all the codes so he called one of his better technicians which said
i think once i have a real problem i will need to find a better dealership.
non of the aam rear axles have limited slip
If you have an Auto you should be able to do a power brake and see if both rear wheels spin and leave marks, or if you have a stick and you know how to do a burn out do one and have someone watch to see. that's the easiest way.
I'm not responsable if you break something.
If you test with both rears off and stop one, it will spin like a straight axle. Apply resistance to both wheels and both should spin equally. It needs some resistance to transfer the torque. Thats why the manual recommends applying a little emergency brake when in very slippery conditions. Sounds good on paper but in SOME rear world conditions it sucks. If you acquired it for straight line traction (grass, pavement, dirt) etc, it works better than others.
The problem is when one wheel is on VERY slippery surface or hung up (like buried, and hung on the axle) the wheel just spins like a straight axle would. The application of emergency brake is SUPPOSE to offset this condition. It doesn't in majority of these conditions.
Your best bet is get someone ELSE to read your VIN, unless someone did a after build install, the VIN should reflect it. They have limited slip, and its made by AAM, its called Tractrite GT. Prior to gen 3 the axles were Dana.
Varmint
18
10-04-2004 09:34 PM
