Lights dimming
Old 11-04-2002, 11:33 AM
wick's Avatar
Lights dimming
During warm up on a cold start the light in the truck if i have the door open goes dim and then brightens up. Its does this over and over untill the engine warms up. Is this normal? The battery guage is going up so I do not see a problem there. Just wondering if this is normal?
Old 11-04-2002, 11:50 AM
UTAH's Avatar
Re:Lights dimming
Well, if they're using the same type of manifold heater my old Cummins (Gen 2) used - it's just the large current draw of the manifold heater cycling on and off.<br><br>I used to really notice it at night with the headlights dimming and brightening when the engine was cold.<br><br>Best to y'all<br>Bill
Old 11-04-2002, 12:29 PM
Moparior's Avatar
Re:Lights dimming
Yes it is normal and I believe UTAH's explanation was correct. It talks about it in the owner's manual, but I don't have mine in front of me right now. I remember reading about it though, and I also notice my truck doing the same thing.
Old 11-04-2002, 05:12 PM
Vaughn MacKenzie's Avatar
Re:Lights dimming
There are tons of these posts EVERY Fall on TDR <br><br>Vaughn
Old 11-05-2002, 12:18 AM
Hunter's Avatar
Re:Lights dimming
TDR?<br><br>U are on dodge-diesel.org son!<br><br>Hate to break your bubble<br><br>Innocent Hunter
Old 11-05-2002, 06:46 AM
UTAH's Avatar
Re:Lights dimming
TDR = The Dues are Required. : ;D<br><br>Best to y'all<br>Bill
Old 11-05-2002, 07:51 AM
Administrator / Scooter Bum
Shovelhead's Avatar
Re:Lights dimming
[quote author=Vaughn MacKenzie link=board=20;threadid=6601;start=0#61873 date=1036451542]<br>There are tons of these posts EVERY Fall on TDR <br><br>Vaughn<br>[/quote]<br><br>OK...I give up.....what part of this statement is incorrect? ???
Old 11-06-2002, 12:40 AM
Hunter's Avatar
Re:Lights dimming
Shovel<br><br>We are shoveling you a bunch of BS!<br><br>It is totally normal for the lights up and down, it is &quot;heating&quot; up the system. After your lady warms up a bit, you will not hear that ;D<br><br>Hunter
Old 11-06-2002, 05:41 AM
Shovelhead's Avatar
Re:Lights dimming
[Homer Simpson]..DOOOOOOOOOO.
Going back to my corner now.
Old 11-06-2002, 02:30 PM
Re:Lights dimming
Just poking some fun <br>I was implying this is one of the worn out topics over on TDR (I knew where I was )<br><br>Vaughn
Old 11-06-2002, 11:35 PM
pwabbott's Avatar
Re:Lights dimming
Shovelhead, the part of the quote is that part which refers to &quot;tons of posts&quot;. Tons can only refers to Mass and Mass must refer to something that can be weighed. You can't weight &quot;Posts&quot; (unless they are fence posts) but, you can weigh BS.
Old 11-07-2002, 07:11 AM
TEDHRS's Avatar
Re:Lights dimming
i am in agreement with the whole manifold heater sucking out the juice till it warms up, but, I made my trip to NC and after driving 423 miles, i stopped to fill er up again and noticed that the lights were doing it. If it just till it warms up, then why does mine do it after it is warm? Just a little question for ya'll.
Old 11-07-2002, 07:17 AM
Shovelhead's Avatar
Re:Lights dimming
[quote author=Sierra Phil link=board=20;threadid=6601;start=0#63292 date=1036647311]<br>Shovelhead, the part of the quote is that part which refers to &quot;tons of posts&quot;. Tons can only refers to Mass and Mass must refer to something that can be weighed. You can't weight &quot;Posts&quot; (unless they are fence posts) but, you can weigh BS. <br>[/quote]<br><br>Vinnie Barbarino<br>&quot;I'm soooooooo confused&quot;............ <br>Maybe I shoulda stayed awake in school.
Old 11-07-2002, 02:52 PM
FiverBob's Avatar
Re:Lights dimming
I just had the same periodic dimming this morning. I was in North Florida where it had dropped down in the 40's overnight. Left the hotel in the dark and noticed the lights dim, then bright, then dim at intervals of about 15 seconds. This lasted about 2 minutes or so, then quit. Then, I remembered this thread. I would have to say it must be something in the heaters. Sure never happened in South Florida - - only have to worry about the AC working right. <br><br>Bob
Old 11-10-2002, 12:50 AM
Rob Thomas's Avatar
Re:Lights dimming
www.psdieselproducts makes an intake heater by-pass, the product senses when the water temp is 160* (I think) and by-passes the heater cycling, less wear on the batteries, alternator, and grid heaters as they draw like, 130amps.
Later, Rob
BTW, I have it, and it does work.
Quick Reply: Lights dimming
