Lifting your rig
Old 12-07-2007 | 04:44 PM
torkmnstr's Avatar
Lifting your rig
So question here. Would there be any problem with rotating the axle a bit to correct the front driveline vibration? I have seen it done many times before and always wondered if it was bad at all, especially on a street driven daily driver. I will be going for 8 in. of lift and this in conjunction with an indexing ring should solve all vibration issues. I know it is a bit more work but I think it would be very worth while. TIA.
Old 12-07-2007 | 04:45 PM
cbrahs's Avatar
get adjustable long arm kit and add a degree or 2 in it that way.
Old 12-07-2007 | 04:49 PM
torkmnstr's Avatar
I dont know if I did not explain it right, I would cut the brackets and reweld, inturn rotating the axle up to be more in line with the shaft.
Not sure what you mean cb
Old 12-07-2007 | 04:51 PM
torkmnstr's Avatar
This should help explain
Old 12-07-2007 | 04:55 PM
ptgarcia's Avatar
You can only go so far before you screw up the castor to a point steering is adversely affected. Don't know where that point is with these trucks but keep that in mind.
Old 12-07-2007 | 06:59 PM
cbrahs's Avatar
I understand what you are wanting to do but that is a ton of work. just like Pauly said, just be careful of the castor side of things.
Old 12-08-2007 | 12:56 AM
torkmnstr's Avatar
I see, thanks guys!
KillerBee
18
06-14-2009 05:23 PM
bigragu
10-08-2008 09:19 AM
Joe T
07-09-2007 06:32 PM
firestorm
02-27-2005 02:31 PM
jlells01
46
12-07-2003 12:03 PM
Quick Reply: Lifting your rig
