Lift pump replacement....
Old 12-18-2007 | 04:42 PM
Landini1's Avatar
I have 50,000 miles on my 3500 2004.5, I am always worried about the lift pump failing.
Will they replace it under warranty before it fails or do I have to be towed in and the pump completely failed before they will replace it with the in tank pump.
Thanks
Old 12-18-2007 | 04:45 PM
Spooler's Avatar
If it kicks out a LP code they will replace it. At least they did mine at 23,000 miles. It's covered under the Cummins engine warranty. 7yr/ 100,000 miles. Last 2 years a $100 dollar deductible is required.
Old 12-18-2007 | 05:15 PM
lamadera's Avatar
You can buy a spare new one on ebay for a little over $200. Makes me feel better on road trips. I can install the new one myself if I have to. Someday I'll upgrade to a better system.
Old 12-18-2007 | 05:18 PM
JP-4.5's Avatar
Buy an aftermarket one and say goodbye to the stock setup... Do some reading and use GDP, AirDog or Fass.
My 2004.5 had the pump on the filter which makes adding an aftermarket pump easier than if it is mounted in the tank which is what Dodge will do if they replace your pump.
I chose GDP-392 and changed mine before it failed. I did not want to risk hurting something else. I was also concerned about hurting injectors with the stock filter so I also added the 2 Micron filter.
Jeff
Old 12-18-2007 | 06:03 PM
lamadera's Avatar
That's a good call, but you likely said goodbye to your warranty. I don't want to deal with any BS if I have injector issues before my warranty runs out. So I'm staying stock until then.
Txwelder
12-18-2023 02:35 PM
mstep3
23
07-27-2010 02:22 PM
Txwelder
05-19-2005 06:10 PM
w4xtc
03-14-2004 09:14 AM
AlpineRAM
01-30-2003 03:24 AM
Quick Reply: Lift pump replacement....
