Lift Pump Problems with 600-610 motors?
Old 04-29-2005, 12:59 PM
truckjunkie's Avatar
Hi - I'm trying to see if there are folks out there that are having problems with their lift pumps on the 600 or 610 motors. Was there a change to the fuel delivery system between the 555 H.O. motors and the 600-610 motors? If so, what was the change? Just trying to get all of the information I can. Thanks....
Old 04-29-2005, 02:42 PM
TAS05CTD610's Avatar
I know the 05's have the lift pump in the tanks now (guess it's a pusher pump hu) but no problems here, only 6000K on the clock though.
Old 04-29-2005, 03:41 PM
PourinDiesel's Avatar
Never had a problem out of my stock lift pump on my 04.5.
It is now just a cosmetic piece/decoration on the engine.
Now I run FASS right to the pump.
03-4.5 have the same lift pump that is mounted on the fuel filter.
Old 04-29-2005, 07:05 PM
Ram_in_Texas's Avatar
Mine was replaced after throwing a code at 12k - can't say if it was actually bad because I took it in for a different problem.
Old 04-29-2005, 10:24 PM
eastmentCTD600's Avatar
25 K on my 04.5 and no issues, change the filter regularly, no other special treatment. Runs GREAT!
E
Old 04-30-2005, 05:52 PM
burlhall's Avatar
No problems yet after 19K miles. The only problem I have had is with the power steering which hopefully will be fixed Monday.
Old 05-01-2005, 09:39 PM
Journier's Avatar
18,000 on my 04.5 now, I thought I had heard that the lift pump problems were being solved for 04.5
guess ill have to trade it in on an 07
guess wishful thinking
Old 05-02-2005, 12:14 AM
jlasich's Avatar
Mine went out at 39,000 miles. A buddy's went out at around 40,000 miles. So, I don't know if that's a magic number or not. Personally, I think I was just running some bad fuel. I did read either on here or TDR that they redesigned the replacement lift pumps and from reading the post, I believe I have the new one. Will see how long it lasts.
Old 05-02-2005, 04:25 PM
bluebull's Avatar
The 05's have the lift pump in the fuel tank and is different than the previous year trucks. 05' have one design, 03-04 have their own design, 98.5-2002 have their own design, 12 valve have their own design.
I don't think there are enough 05's with enough miles on them yet to tell if this is the solution, but this design has to be better than any previous 24 valve designed lift pump. Electric pumps are designed to push fuel, not pull fuel ten feet+ and then push.
Old 05-02-2005, 07:52 PM
thejeepdude's Avatar
I'll bet if you end up with an '07 you'll be wishing all you had was lift pump problems. At least that's a remediable problem. 2007 is going to bring all the joys of the next phase of pollution control... EGR? Who knows at this point, but I don't think I'll regret that I bought when I did...
Old 05-02-2005, 08:13 PM
big red psd cc's Avatar
Mine died at 10,000 almost to the mile.
Took out three injectors with it.
Runs great now........especially with the Holley Blue Pump now.
Old 05-02-2005, 09:57 PM
Muzzy's Avatar
Bluebull is exactly right about the location of the pre 05' lift pumps. They are not designed to be pulling fuel from all the way from the tank to the engine. Plus they are a good 12"-18" higher than the fuel tank so they are pulling it up hill.
When I installed my Holley, the instructions specifically say to install the pump as close to the tank as possible and at or slightly below the bottom of the tank to take advantage of the siphoning effect.
They seemed to finally get things right with the 05's by putting it in the tank, but the volume and pressure still isn't there for doing any mods.
-Muzzy
Old 05-03-2005, 05:53 AM
Locomotion's Avatar
[i]
-Muzzy
Think that may have have been done intentionally?
Old 05-03-2005, 10:18 AM
bigblock2stroke's Avatar
How did the lift pump take out the injectors?
I don't see the relation between the lift pump failures and the failing of the rest of the high pressure system. It was very apparent with the VP44 failing if your lift pump failed. but I don't think the same is true for the common rail systems.
Old 05-03-2005, 12:23 PM
bluebull's Avatar
I was told by the deal (take it for what it's worth) that on the 05's if the lift pump fails the high pressure pump will not work and the engine will die. Something about the CP3 in the dodge trucks that do not have an internal pump in them. Like I said, take it for what it's worth coming from a dealer, some seem to know what they are talking about and some do not.
Quick Reply: Lift Pump Problems with 600-610 motors?
