Lift pump install
Old 01-28-2010 | 03:14 PM
MR. GADGET's Avatar
Lift pump install
I just ordered a lift pump from Geno's to put in the truck.
I was getting long starts and the old one was not pumping tap on it then it runs.
So what are the tricks or any short cuts to install the factory type of lift pump on the filter barrel.
Looks like a few screws and hose with pre filter?
Old 01-29-2010 | 06:09 AM
papaduck's Avatar
Very easy to change. Remove the fender liner (easy to remove) and it will be easier to reach the pump over the wheel. Should take only minutes to change out the pump.
Old 01-29-2010 | 09:28 PM
moto953's Avatar
Papaduck hit the nail on the head about removing the inner fender. Another good point is to make sure that you drawl the bolts back in even or risk pinching the o ring. Not a hard fix at all.
Old 01-30-2010 | 09:33 AM
04 Diesel's Avatar
How do you disconect the the fuel line? It is some kind of quick disconect.??
Old 01-30-2010 | 12:02 PM
papaduck's Avatar
The quick disconnect may require both hands. Press the tabs on the disconnect and squeze and with the other hand pull it apart. You can put a wire tie or twist tie around the tabs and pull it up tight to hold the tabs in.
It may be easier to get at the disconnect from under the vehicle.
Old 01-30-2010 | 02:38 PM
04 Diesel's Avatar
when I disconect the line will alot of fuel come out? I dont have to do it yet but when I do I want to be ready.
Old 01-30-2010 | 04:42 PM
papaduck's Avatar
You will get a small amount of fuel out of the upper line and pump. The disconnect is above the tank so the flow will stop.
Txwelder
12-18-2023 02:35 PM
BC847
04-29-2019 10:35 PM
caper
04-16-2006 01:45 PM
Txwelder
05-19-2005 06:10 PM
GSP
10-13-2004 12:35 AM
Quick Reply: Lift pump install
