Lift pump fuel leak...need shop referral
Stranded with a leaking lift pump in Redlands, CA. Can anyone suggest a good diesel shop. Dodge wants to install in tank pump for $1,000.
If you have the original fuel filter cannister mounted external low pressure fuel pump, it's readily available and a very simple swap.
http://www.genosgarage.com/REPLACEME...MP_FPD4089602/
I recommend a frame mount aftermarket pump. Mount it right under the drivers seat area. Also add a big line kit. It's just a bigger fuel line. I have one from Glacier Diesel. very easy ti install. there are others out there that will more than do the job.
schu777
09-10-2009 08:50 AM
royta
02-11-2005 01:07 PM
