LF3894 on a 2005?
LF3894 on a 2005?
My dad has a 2005, and I am wondering if his engine (I havent looked at it yet) uses the same oil filter as my 1998 12valve.
I know my previous 24v could use the same filter, and I am just wondering if the new engines are any different.
We want to buy cases of filters, and split the cost.
Thanks.
phillip
Thanks.
phillip
Yes, it can use the same filter. The new filter has a fluted can, which lets you get a cap-style filter wrench on it. I think the new Part # is 16035 or something like that.
Anyhow, the 3894 will work just fine.
jlh
jlh
Hohn is correct. The 3894 works fine. I use it on my '04. The ONLY difference between it and the 16035 is the fluted end. If you don't use the oil filter wrench that fits on the end and uses the flutes, then you don't need them. Generally the 3894 is about a buck a filter cheaper. Of course you can use the 16035 on your Dad's truck also. Either works on either.
Thanks guys. You can get them by the case from Geno's. You just have to call and ask.
I like getting a case becuase I hate re-ordering, and I know they will get used. Between me, my brother, my dad, and my fatherinlaw, the filters will get used.
Originally posted by handymantim
The cheapskate in me wants to know......where are you getting them by the case and how much?
Thanks.
Thanks.
It's worth mentioning that the Fleetguard filters used in OTHER ISB5.9 applications WILL NOT WORK on your truck.
The filter head is different in the Dodge application. The threaded part on the Dodge application is smaller diameter, so an RV filter will be too big to screw on.
Don't ask how I know this
jlh
jlh
popeyesides
42
08-08-2006 11:49 AM
Mcmopar
13
09-09-2005 05:04 PM
