Leaky CP3 or GDP 2 micron filter?
Old 11-27-2008 | 06:46 AM
trik396's Avatar
A long time ago I thought I had a cp3 leak but as I traced the fuel up past the cp3 and onto the rail. Turns out one or two of the injector lines needed a slight tightening up at the rail. I didn't get crazy with torque but I distinctly remember putting the wrench on one and it turned without any pressure on the wrench
snugged it up and it's been fine ever since. and don't do this with engine running.
Old 12-21-2008 | 02:43 PM
rallydriver's Avatar
Update
UPDATE:
Turns out the GDP MK-2 was leaking on the clean side of the filter (from the housing to the CP3). The diesel managed to leak past the Permetex PTFE thread sealant I applied, so for anyone's future reference I would advise against using PTFE thread sealant.
What I used to better seal the pipe fittings was a yellow colored teflon tape from Home Depot made with PTFE to seal pipe and protect against diesel, and it is rated to 100psi. So far no leaks or drips, but only time will tell if the tape works better than the thread sealant.
-Chris
Old 12-21-2008 | 10:01 PM
CRXsi's Avatar
Interesting since I used PTFE as well...I have been meaning to redo all my fittings with diesel rated tape to see if that helps, Thanks for the heads up.....
03RAM2500
01-11-2009 05:21 PM
Franklin
32
05-15-2008 07:38 PM
Spooler
14
10-26-2007 12:50 AM
JohnnyH
07-12-2007 12:43 AM
checkster
09-22-2006 09:30 PM
Quick Reply: Leaky CP3 or GDP 2 micron filter?
