leaky ABS hydraulic control unit
Old 03-01-2007 | 10:07 PM
jimku's Avatar
I really need some input from you guys and gals. On top of the unit I have 2 big electrical connectors and at the bottom I have 2 rubber plugs w/ occasional oil coming out of the back plug. ANY SUGGESTIONS PLEASE. It is an05' 2 wheel drive QC w/38k miles.
thanks,
Old 03-04-2007 | 02:19 AM
Its All Good's Avatar
If its leaking you should have it replaced, this could be costly. The HCU is used for the anti-lock brake function, its primary function is to hold the fluid under pressure until its needed (when the anti-lock system is activated). You can still drive around because the HCU has nothing to do with regular braking functions, just anti-lock function.
Old 03-04-2007 | 02:22 AM
Oh yeah, if you decide to replace the HCU yourself, you will need a DRB III scan tool to bleed the CAB and HCU. That's why I tell my customer's I only can fix certain things on late model vehicles.
Old 03-04-2007 | 03:22 PM
vzdude's Avatar
DTR's 'Go to Guy'
The HCU actually releases pressure when it sees a brake locking up. Other than that you can bleed the brakes by doing a normal bleeding procedure, then get on some gravel and have the abs engage and then bleed them one more time. This has worked well for me, and I HAVE a DRBIII . The DRBIII isn't really necessary, and I have not noticed one iota of difference doing it either way. I also haven't seen many HCU's actually leaking. Clean it off with some brake clean, and have a partner hit the brakes a couple of times and see. If you have to replace the CAB (controller), you can use a buddies or your own aftermarket programmer to program the revolutions per mile. They can be found at tires.com under the info tab.
Andy
KennyHaynes
08-17-2012 06:41 AM
RussianVolk
06-29-2010 01:13 AM
2500
03-13-2008 12:21 PM
jimku
03-02-2007 09:41 PM
hotmopr
06-29-2006 10:22 PM
Quick Reply: leaky ABS hydraulic control unit
