leaking radiator
Old 03-15-2006 | 10:08 PM
longbed's Avatar
Angry leaking radiator
2003 looks like the lower fan shroud has rubbed a hole in the radiat or. Is this common? any easy fix without removal? How hard to get it out?
Old 03-15-2006 | 10:51 PM
torquefan's Avatar
I saw that on an 03 not too long ago. Worn by the part of the shroud where there's a channel for the elec. fan clutch wiring to run, if I recall. The rad wasn't too bad to get out. I ended up putting in a whole new radiator. I just don't trust aluminum cores for long-term repairs.
Old 03-16-2006 | 06:40 AM
thunderdawg's Avatar
Seems to be fairly common on 2003 models (I caught mine in time thanks to a post here). I'd replace the radiator and shim the shroud to keep the problem from recurring. Since I caught mine before the shiny spot became a hole, I just split a 4"-6" long piece of vacuum line and slipped it over the bottom of the shroud which seems to keep it from rubbing.
Old 03-16-2006 | 05:17 PM
longbed's Avatar
I think dodge should be sending out some notice about this. They see this stuff all the time. For a 5 cent part i have a hole in a 400.00 radiator. Its insane.
Old 03-17-2006 | 02:31 PM
CG98x's Avatar
Mine did it too. Dodge said not covered. It happened at 69000 miles on mine. I put alumaseal in and it has been fine for 6000 miles.
Old 03-17-2006 | 03:57 PM
rammtuff's Avatar
Have the 2 cores that are leaking soldered off. It will last a long time
8liter
09-22-2012 10:19 AM
onemoretruck
11-20-2006 06:53 PM
gottahavediesel
12-25-2005 06:55 AM
Kass
08-31-2005 05:37 AM
Carnage
10-20-2004 02:31 PM
Quick Reply: leaking radiator
