leaking fuel line at pump
Old 03-24-2005 | 08:14 AM
CCOUGHRAN's Avatar
looks like the return fuel line(i think) is leaking. this is the top line on the punp, it has about a 14mm hex head bolt going through a metal line, the line is about 1/4-3/8 diameter, and only about 8-10 inches long which then connects to a rubber line.
the hole is where the tubing connects to the cast piece that the bolt goes through, so i doubt it can be patched.
is this a dealer item, maybe a hydraulic fitting house will have them? any idea exactly what this is called so i know what to ask for specifically.
thanks, chris
Old 03-24-2005 | 09:42 AM
CCOUGHRAN's Avatar
looks like i figured out the name of the fitting etc. just need a good place to get one.
it is a banjo fitting, with 8" of 5/16 tubing to connect to hose. it is the return fuel line.
cummins does not have it in stock in houston, and the dodge house has one but it is 250 miles away from here.
any ideas one where else to look for a banjo fitting?
thanks, chris
txasylum
03-22-2008 02:47 PM
Thrust
08-05-2007 02:04 PM
adidasman23
14
11-13-2006 01:14 PM
mr T
09-01-2006 05:41 PM
99 cummins
09-30-2005 02:15 AM
Quick Reply: leaking fuel line at pump
