Leaking fuel at the common rail??
Hey all. Was detailing my truck today decided to clean up the engine a little. Saw what could have only been a bit of fuel seaping out of the common rail where the metal lines go to each injector. I sprayed it down with simple green and it cleaned right up. I also tightened up each fitting about 1/8 turn to see if that will stop it. should I worry about this minor seapage? I'm only running the Quad tow box 65hp.
Jamie
Jamie
just watch it you should be fine. I was changing my fuel filter today and noticed I had some residue around the hard line fittings by my rail...I cleaned it off and tightened it up. Then I idled it for a few minutes..... no leaks yet
RobV2500
12-30-2008 05:41 PM
DMS1707
17
10-23-2008 08:30 AM
kidhulr
04-18-2008 12:37 PM
kidhulr
17
03-19-2008 10:28 AM
