Leaking coolent, whats wrong?
Old 11-01-2008 | 07:44 AM
bige41084's Avatar
So heres my problem, I noticed a week or so ago that I had a few drops of coolent under my truck, I looked under the hood and noticed that the overflow hose right behind the cap on the radiater had some coolent around it and also on the airbox, I pushed the hose on tighter and figured I fixed the problem. A day later, same spots, this time I looked under the truck and I can see that it looks like it may be dripping from mutiple spots. It nomally only drips after the truck has been running and then is turned off. Is this a reacurring problem for this year truck? What could the problem possibly be? Its still under warrenty so Im gonna call the dealership here next week.
Old 11-01-2008 | 08:33 AM
Roger G's Avatar
Put a clamp on that hose and that should take care of it. I had the same problem and found a thread on here about putting a hose clamp on.
Old 11-01-2008 | 09:09 AM
RonP's Avatar
couple places seem to occur a lot. That hose, the small hose on the side of the engine and the block heater. My truck drove me crazy with the dripping when I first got it. The dang block heater need 2 solid turns to be tight. never leaked a drop after that.
Old 11-01-2008 | 09:45 AM
bige41084's Avatar
Can someone tell me more about this block heater??? COme to think of it, this only started after I plugged my truck in for the first time. Do you mean the heater cord needs tightened? or something eles? If its somethine eles can someone explain where and how?? This is driving me crazy!
Old 11-01-2008 | 09:48 AM
RonP's Avatar
Follow the cord back to where it plugs into the heater on the side of the block. The heater is kind of like a water heater element in your house. It just screws into the side of the block. You can take the cord off and use a socket or like I did, just use a big adjustable wrench and tighten it up with the cord still on.
Old 11-01-2008 | 09:53 AM
bige41084's Avatar
Thanks, Ill give all these things a look at and try, hopefully one of them is the solution im lookin for!
Old 11-01-2008 | 12:12 PM
BigIron70's Avatar
Cummins Guru
Usually the hose clamps on external trans cooler right side engine behind turbo are not tight and hose starts leaking. Also check water pump for leakage will notice coolant leaking down by ac compressor right front of engine. Also check for broken hose clamps at lower radiator hose. I have found these to be the most common places for coolant leaks. Good Luck
Old 05-06-2009 | 04:41 PM
stroker101's Avatar
"Also check water pump for leakage will notice coolant leaking down by ac compressor right front of engine."
this is where i see coolant dripping from. called dodge and asked if this is covered on the 5 yr/ 100k mi warranty...reply was what i wanted to hear, lol. as soon as i get a day off (next friday, yeah next week friday) i'll be taking my trk in for repairs
Old 05-07-2009 | 10:04 AM
matt69olds's Avatar
I had a small coolant leak on my truck also, really had to heat soak before it would show up. Turned out to be the heater? hose under and behind the turbo. It is a foil covered hose about 4 inches long. Tightened the clamps and all is good
Old 05-07-2009 | 10:18 AM
cody459's Avatar
Thats a good place to start looking, happenend to mine and a couple of friends trucks. Right there can be diecieving because if its happening during a time running your ac you see the spot under the truck and right it off as condesation from the ac until you smell the coolant.
Old 05-07-2009 | 03:02 PM
Texasimport's Avatar
There was a problem with a short 2 in hose between the motor and heater coil in your dash. Look around behind your turbo and you will see the little critter. Lots of folks have enjoyed leaks from there including me. Dodge sawpped out the hose for one that actauuly fit properly, issue gone
Buffman88
03-18-2007 01:02 PM
White Rat
12-04-2006 09:58 AM
DuaneWKKC
09-25-2005 04:02 PM
thumbs
10-01-2004 04:53 PM
thumbs
06-12-2003 12:18 PM
Quick Reply: Leaking coolent, whats wrong?
