Leak From Inspection Plate
Old 07-18-2011 | 01:43 PM
Nate-03 D's Avatar
Question Leak From Inspection Plate
I just recently installed my trans over the weekend. Drove it all weekend without any issue, shifted good and no leaks anywhere.
I come out of the house this morning and seen a small puddle of tranny fluid, dripping out of the inspection cover. Is this an indictor that I over filled it? I put in 11 qts, I was a little over the "full" mark on the dipstick for my final reading.
Thanks.
Old 07-19-2011 | 05:07 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
Probably not. It would indicate a leaking front seal where the input shaft goes into the trans. The converter has a big seal there and if you nicked it putting it in that's probably what's causing it to leak.
Old 07-19-2011 | 10:11 AM
Nate-03 D's Avatar
I was pretty cautious when sliding the TC on the shaft, I rotated it left and right to seat it. Then I stabbed in the trans. Is it possible I damaged the seal while installing the tranny? I got sortive ruff with it.
I just walked outside and their isn't a single leak on my driveway now?
Old 07-19-2011 | 11:28 AM
Sur5er's Avatar
Check the fluid level again, and the seal on the fill tube. If it stopped leaking say "thanks" and drive on!
Old 07-19-2011 | 06:08 PM
cdennyb's Avatar
WHAT HE SAID!!!... you got lucky.
btoops
08-13-2011 02:24 PM
ArXane
14
04-18-2009 08:50 PM
ptgarcia
05-15-2008 09:32 PM
DL1221
07-23-2006 01:45 PM
Quick Reply: Leak From Inspection Plate
