Latest oil analysis - should I worry about the iron?
Old 02-06-2009 | 12:10 AM
estesbubba's Avatar
I got my latest OA from Blackstone and they say my iron is a little high. They say my 7500 intervals are fine, but if the iron bothers me, to shorten them. What does higher than normal iron mean and is it anything to worry about? This report was using Valvoline Premuim Blue CJ-4 oil.
Old 02-06-2009 | 01:38 AM
dozer12216's Avatar
The iron is tending downward to some extendt. It is however puzzling as advised by Blackstone. In addition look at the Moly and Potassium????
How much towing do you do? I saw my highest iron reading after a very long extremelly difficult tow, but it took 20,000 to get were yours is at 7500? HUM!!!
The first EOA was with factory oil and can understand the values high on wear in. Your engine should be worn in at this time however. How about looking carefully at the air filter system. See if residue is on inside of air tubes. I'm sort of like Blackstone. Run another and see. Intresting, keep us posted.
Old 02-06-2009 | 07:59 AM
trik396's Avatar
Try running a different oil... maybe premium blue extreme.
Common
05-23-2007 07:26 AM
DennisT
05-11-2007 08:58 PM
flyfsh70
10-05-2006 02:40 PM
kens_isb
24
02-18-2006 07:16 PM
Badd Dogg Guy19
35
06-09-2005 08:42 PM
Quick Reply: Latest oil analysis - should I worry about the iron?
