Knocking in engine 03 cummins
Old 08-08-2008 | 05:32 PM
Anger890's Avatar
I took the truck to get my nephew in the truck this afternoon, it ran fine on the way there, I stopped and loaded him up and started the trip home a whopping 1 mile. After turning out of the parking lot and accelerating for approx 1/3-1/2 mile, a loud knocking started in the engine compartment, with lots of white smoke from the exhaust, I immeadiately stopped the truck as soon as it was safe at the top of a hill and checked the following.
Oil, Clean and full about 1k before oil change, running Cummins premuim blue synthetic.
Edge EZ, removed from the truck. (no change in running)
Replaced fuel filter, no water in the fuel and the water in fuel light was not on. Fuel filter had 7k miles on it. This tank of fuel has 160 miles on it.
Started the truck and got it rolling down the hill to my house.
Anytime the engine is run there is a loud knocking and white smoke pouring from the exhaust.
All Vital fluids are full and clean, I can not see any leaks anywhere on the undercarriage. Anyone have an idea on what left the building? Injector?
Old 08-08-2008 | 07:33 PM
doorguy's Avatar
I think I see a set of injectors in your future.
Old 08-08-2008 | 09:08 PM
mahdey's Avatar
yes, check injecrors asap
Old 08-08-2008 | 09:21 PM
cincydiesel's Avatar
With the engine running feel each cylinder by hand to check for injector knock.
Old 08-08-2008 | 11:05 PM
Anger890's Avatar
Thanks for the input guys, I will check the injectors when I get home from the lake. It sucks, whats the recommondation, replace with stockers or upgrade?
Old 08-09-2008 | 07:50 AM
Jeff in TD's Avatar
What a bummer. How many miles on the truck?
Anyhow, if you are going to replace them anyway, I suppose a set of Mild aftermarket ones that claim better fuel mpg would be my choice...
Also, I see these were your first posts. Welcome.
Old 08-09-2008 | 09:21 AM
Anger890's Avatar
Just under 90k on the truck, any suggestions on injectors? It really bums me out as I drove the truck for work this week, 1600 trouble free miles and then 1 mile from the house, craps out.
Nice to have a knowlegable forum to get answers on.
Old 08-09-2008 | 10:38 AM
Tony T.'s Avatar
Actually your luck was with you only being a mile away the way I see it . With it being a 03 and just under 90K miles it should be covered under the 100K warranty. My 03 has the 100K/7 year deal warranty, check into that first.
Tony
Old 08-09-2008 | 01:37 PM
Anger890's Avatar
Tony
I hear you on being 1 mile from home as opposed to being out in the miiddle of nowhere. Kind of Ironic though. I will check in with the dealer on Monday, they should be able to run the VIN and let me know what warranty coverage is still active correct?
Old 08-09-2008 | 01:40 PM
Anger890's Avatar
Could you explain this a touch better? Do you mean run the engine and feel each injector? What am I trying to determine when checking the injector? Is the knock coming from the injector? Kind of a noob when it comes to the diagnosis on a diesel.
Old 08-09-2008 | 03:59 PM
Jeff in TD's Avatar
I think I'd wait to even touch it until you figure out if it is still under warranty...
Even if it is just slightly past on time, maybe the dealer guy can go to bat for you and get part of it covered. I'd guess you may have to show receipts for fuel filters, though.
Old 08-09-2008 | 08:40 PM
What he said ^^^^ However if you have a injector knocking you can sometimes feel it on the side of the cylinder wall. My buddies 7.3 dropped one and you could definetly feel it while the truck was running
Old 08-10-2008 | 04:33 PM
DWitcher's Avatar
Let the exhaust manifold cool completely off and fire it up. Give it a couple stabs with the accelerator and feel the exhaust manifold at each cylinder port. The one that is the hottest will be the one over fueling causing the white smoke.
Old 08-10-2008 | 04:43 PM
MikeyB's Avatar
Mark each exhaust runner with a piece of crayon, and see which one either melts first or doesn't melt at all.
MikeyB
Old 08-10-2008 | 05:11 PM
1slo_MM's Avatar
Welcome to the forum. To bad this had to be your first post...
-dru
Quick Reply: Knocking in engine 03 cummins
