Knock, Knock, Knock...What's Making My Truck Knock??
Old 09-28-2006, 01:21 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
I drive by there in the morning and in the evening, but I work downtown. Of course, stopping by that area on my way home gives me a good excuse to stop at Freebirds and pick some burritos up for dinner.
This fuel...as well as the tank before it...came from the Murphy USA in Georgetown. I've used Murphy a lot in the past and never had any problems, but this was only the second time I've filled up at this particular station.
Old 09-28-2006, 01:26 PM
P.J
P.J's Avatar
I thought the engine and drivetrain warranty cut off at 70,000 miles??
5 Year/100K, take it to a dealer if the other ideas don't help.
Old 09-28-2006, 01:28 PM
Hoss's Avatar
That's good to know. For some reason I was thinking the engine had a 7 year / 70K mile warranty. I really don't want to take it to a dealer, but I guess if I have to then I have to.
Old 09-28-2006, 06:33 PM
973604x4's Avatar
Howdy Hoss!
aaaahhhhhh FREEBIRDS!!!!!! thats where i need to go right now!
That 7/70 ended when?
or was that extended? cause i was done at 36k.
Old 09-28-2006, 06:42 PM
Crimedog's Avatar
36K should be the bumper to bumper. You should have at least the 7/70 for your powertrain warranty.
Old 09-28-2006, 08:10 PM
973604x4's Avatar
oh ok. oh well i lost my warranty at 32k anyway
Old 09-28-2006, 08:17 PM
Hoss's Avatar
Well, I bought a bottle of Sea Foam and dumped it in the tank tonight. Hopefully my drive to work tomorrow will clean the injectors...if that's the problem.
I also checked my oil level. No signs of diesel in the oil, so that's a good thing.
I'm really starting to think it's bad fuel. It's never done this before and it started almost immediately after I filled up my last tank. I may top it off with some B20 tomorrow and continue doing that every time it gets down to the 3/4 mark. If it is bad fuel, maybe diluting it with some good B20 will help.
Thanks for the help...and if anyone else has any ideas let me know.
Old 09-29-2006, 07:14 AM
Hoss's Avatar
Well...after driving 30 miles to work this morning there is no difference. It's still idling rough and it's still knocking. I guess I'll have to leave early today and drop it off at the dealership.
Old 10-02-2006, 10:31 PM
abc4yew's Avatar
I hate to say it but it sounds like my truck did....with a dropped valve seat and valve...and the piston beating against the valve and seat for almost a year. Tell the dealer that's what you think it is then you get a new headgasket, headstuds torqued, and you get to check your valve train out. Or you could just get them to check your valve lash on all rockers. Sounds valve related to me.....but what do I know...I'm an amateur at this. KS
Old 10-02-2006, 11:19 PM
HorseHauler's Avatar
Well what did you find out Hoss?
Old 10-03-2006, 06:05 AM
Geico266's Avatar
Well? Hoss what happened?
Old 10-03-2006, 06:17 AM
Begle1's Avatar
He probably came home with a Duramax.
Old 10-03-2006, 06:18 AM
TEX37's Avatar
2006 4x4 Dodge Dually Diesel With 2100 Miles On It, When You Let Off The Gas Pedal It Has A Loud Knock In The Drive Train, And It Can Be Heard Going Over Railroad Tracks. Dealer Says Its Normal For A 4x4 But They Have Had It In The Shop For Two Weeks And Its Still Not Fixed.
Tex37
Old 10-03-2006, 06:42 AM
Geico266's Avatar
Tex37
Welcome to DTR Tex37
Better start another thread all your own on this problem. It won't get the "attention" you need way down here in Hoss's thread.
Old 10-03-2006, 12:53 PM
Hoss's Avatar
Basically, it was a clogged fuel injector combined with a "bad fuel injector connector"...whatever that is. It was all fixed under the engine warranty and I didn't have to pay a dime. Now it purrs like a kitten....a very BIG and MEAN kitten.
Quick Reply: Knock, Knock, Knock...What's Making My Truck Knock??
