Intectors?
Old 09-02-2014 | 07:17 PM
cmdawson's Avatar
Intectors?
So on top of my fuel mileage being on the low side I've noticed something my truck does that I've never really heard of. When the truck is in neutral or park and you rev it up and let off the throttle it will sputter and takes a long time to return to idle. Has anyone heard of this and is it a sign of any future or current problems. No engine lights are on.
Old 09-02-2014 | 07:51 PM
BigIron70's Avatar
Cummins Guru
Leaking injectors usually causes this, to set check engine light you will need to update PCM, new code will then set indicating injector return flow is excessive. read SB
File Type: pdf
Old 09-02-2014 | 07:55 PM
cmdawson's Avatar
Are there any other symptoms I should start seeing?
Old 09-02-2014 | 08:23 PM
rockcrawler304's Avatar
Any smoke on start up when the engine is cold?
Old 09-02-2014 | 08:32 PM
cmdawson's Avatar
It puts out a light haze when you start it and when ever you accelerate it puts out like smoke..it's not white
Old 09-04-2014 | 03:48 PM
cmdawson's Avatar
Anyone?
Old 09-04-2014 | 06:53 PM
mini14's Avatar
Mines been doing that for years. It takes a second or 2 to bleed off the fuel pressure spike. I've searched many times for answers to the gray haze and most often replies were its normal
Old 01-18-2015 | 06:15 PM
cmdawson's Avatar
So something new I've noticed is its starting to idle a little rough rpms fluctuate almost like a slight lope. It doesn't do this all the time but on occasion.
Old 01-27-2015 | 05:42 PM
cmdawson's Avatar
Could this be the lift pump going out?
Old 02-02-2015 | 03:58 PM
Z-MAN's Avatar
Nope, it's your injectors getting clogged. Just my opinion. I took mine out last month and they were miserable. I had the same symptoms among other problems. After taking my injectors completely apart I discovered their nozzles being extremely dirty with a number of orifices not working on every injector. Check the pics on my thread.
