Intake Grid Heater
When did the check engine light come on? After you started the truck? Sometimes if you start the truck before the wait to start light goes out it can throw a code for the grid heater which is basically just a low voltage trouble code. From starting the truck while the gird heater is on you draw too much voltage cause a low voltage trouble.
Had the same code come up on mine back in October, long story short trips to the dealer, a few computer reflashes, and a new intake heater, no fix. The 4th and final trip the tech told me that they recieved a new flash that morning, no problem since.
Mine started on the first cool morning in the fall that the intake heater needed to come on. Turn the key, heater light came on for a few seconds, light goes out, start the truck (with no issues, started and ran fine) CEL came on when the truck was started, happened 3 times before the last ecm flash, been fine since.
Check this thread out...
https://www.dieseltruckresource.com/...d.php?t=217743
CTD_Neil
03-20-2007 11:49 PM
