Install Fuel Pressure Gauge Questions?
Old 01-29-2010 | 10:24 AM
  #61
kkime's Avatar
ok thanks but what about the line connecting to the banjo?
Old 01-29-2010 | 01:51 PM
  #62
AH64ID's Avatar
You shouldn't be changing that.
Old 01-29-2010 | 01:53 PM
  #63
kkime's Avatar
Im not changing the fuel line, I meant the one Im hooking into the banjo that goes to my sender unit for the gauge...
Old 01-29-2010 | 02:09 PM
  #64
AH64ID's Avatar
Do the same as the sender, light teflon and not on the last 2-3 threads.
Old 02-01-2010 | 05:47 PM
  #65
kkime's Avatar
Ok I jut got everything installed today and started the truck and its not showing any pressure, I tapped into the cp3 banjo bolt one closest to radiator and double checked the ground and nothing if I take the ground off the gauge reads 105 then ground it and it goes to 0, I dont know what I did wrong, why this didnt work right, any suggestions???? Also I did not install the snubber so I might try it with it next but I dont think that would make a diff of not showing any pressure at all?????
Old 02-01-2010 | 06:34 PM
  #66
AH64ID's Avatar
Any photos?
Old 02-01-2010 | 06:36 PM
  #67
kkime's Avatar
no not yet
Old 02-01-2010 | 07:29 PM
  #68
kkime's Avatar
how do I put pics on this site i got em my computer now??
Old 02-01-2010 | 07:35 PM
  #69
AH64ID's Avatar
upload to photobucket and then use the link with the [IMG] around it.
Old 02-01-2010 | 08:35 PM
  #70
kkime's Avatar
where is photobucket?
Old 02-01-2010 | 08:48 PM
  #71
Fisherguy's Avatar
www.photobucket.com
Old 02-01-2010 | 09:51 PM
  #72
kkime's Avatar
http://i1006.photobucket.com/albums/af182/kkime/053.jpg
Old 02-01-2010 | 09:52 PM
  #73
kkime's Avatar
http://i1006.photobucket.com/albums/...kime/052-1.jpg
I hope these worked ?
Old 02-01-2010 | 09:54 PM
  #74
Fisherguy's Avatar
Go to your image on photo bucket and just click the IMAGE link to copy it, then paste it in your post directly.
That bigg hose goes to your gauge?
Old 02-01-2010 | 09:55 PM
  #75
AH64ID's Avatar
That looks correct.
I am not sure why your not getting a signal. You may consider grounding the sender, I have heard of that issue on other senders.
Quick Reply: Install Fuel Pressure Gauge Questions?
