Injector(s) noise?
Injector(s) noise?
I just got back from a 1200 mile trip and have noticed (for the first time) my injectors being audible from inside the cab. Now, I almost exculsively drive with the radio on fairly loud so it's quite possible (and probable) that the noise has been present all along and I've never been able to hear it until now.
To describe the noise it just sounds like an injector "firing/pulsing" but I found it a bit odd to be able to hear it inside the cab. It's very faint and with the a/c or vent on I can't hear the noise. It is RPM dependent and when I let off the accelerator it goes away.
When I got home this evening I raised the hood and listened at idle. It's definetly audible and on the "#1" fuel line (forgive my imaginative explanation) and the "#5" fuel line you can actually feel the fuel pulsing through the line. With the other lines I cannot "feel" the injectors firing.
Any ideas?
TIA!
Any ideas?
TIA!
Doh! I updated my sig in my profile but it didn't show up on the original post. I'll include this post until I figure out why my sig isn't showing.
2004.5
2500 4x4 Short-bed
48RE 3.73's
315/70/17 BFG A/T's
Quadzilla Race
2004.5
2500 4x4 Short-bed
48RE 3.73's
315/70/17 BFG A/T's
Quadzilla Race
Mine has the same sound as yours and all the dealers tell me its normal, the problem is the sound was not there when new and has only gon't louder as the miles roll by. I'm really thinking hard about trading her this weekend on an 06.
I have tried every injector cleaner on the market and I mean everyone of them with no change to the sound. I had the #3 injector replaced after it failed driving home to San Antonio which caused all the engine oil to be pushed out leaving only diesel fuel to lube the engine for some 150-200 miles.
Wow! A surge of replies--thanks!
I changed the fuel filter yesterday and the sound seemed to be a little lower (volume wise). I also checked the oil level and all is fine there so that's a good indication. Strangely, I didn't think to turn the quad off and check the noise--I'll give this a shot as well.
All these injector problems suck!
Originally Posted by 4x4not
When you are forcing 25,000psi fuel through a tiny little hole, things need to work just right
