injector replacement
Old 03-03-2015 | 06:09 PM
dadzram73's Avatar
Well the dreaded issue has arrived. Started running rough about three weeks ago. Only at first start up, once it reached full op temp it was fine. Until last saturday, wouldnt stop running rough. Took her in for diag, was told #5 is dead and #2 is 50%. She has 365k on her all original. Going to replace all 6.
Has anyone heard of dumping ATF in the fuel tank?
Any advise before I give the green light. Should I be looking AT something or FOR something else?
Any news good or bad would be extreemly helpfull!
Old 03-03-2015 | 07:05 PM
ssteve58's Avatar
If you are going to replace the injectors, don't put any atf in the tank. Sounds like its time to replace them. Look at new ones you can get them for around $330 each from Injectors direct.
Old 03-03-2015 | 07:08 PM
12valvedutchy's Avatar
Once you replace the injectors, I would highly recommend adding an after market lift pump, and upgrading the filtration system (Bosch recommends 2 micron while dodge supplies i believe 7micron or greater). 365k on original injectors is very good! What year is the truck? If it is a 04.5- 07 I wouldn't worry about an aftermarket lift pump unless your going to add a tuner etc. The factory liftpump on the 03- early 04 models that mounted to the fuel canister was mediocre at best. As for ATF I have no experience, but I used to add ashless two stroke oil when filling up. I have 40k on reman injectors with no additives and no issues thus far. just my .02.
Old 03-04-2015 | 08:33 AM
dadzram73's Avatar
She's an 05 and has ran awsome until last week. So you think i shouldn't worry about the lift pump then? I will change the filtration though to 2 micron. Not sure what injectors i will be getting. What do you guys think?
Old 03-04-2015 | 08:38 AM
dadzram73's Avatar
More than one person has told me about the ATF, so thats why I'm asking. Not sure what to do. Wanna keep drivin her for another 300k, know what I mean.
Old 03-04-2015 | 10:36 AM
I would check your fuel pressure coming from your OEM pump and then weigh your options. I can't remember what the pressure should be at startup/idle but I think it was in the neighborhood of 10-12 psi at the fuel canister. Also, check these guys out for some injectors. They are the best of the best! http://www.exergyperformance.com/doc...y_products.pdf
Old 03-04-2015 | 11:40 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
ATF was something they did in the old days...however it is a nono with the modern ATF formulas. It now contains friction modifiers and stuff that is hard on injection systems...it is specifically made NOT to burn!
Old 03-04-2015 | 03:22 PM
dadzram73's Avatar
Makes perfect sense, thank you. Is there in your opinion a good additive to use or just dont use anything at all like 12valvedutchy
Old 03-04-2015 | 03:23 PM
dadzram73's Avatar
Great info, thank you very much for you help!
moparsupremist
04-20-2005 11:33 PM
rebel05
02-14-2005 08:13 AM
argve
01-03-2005 06:56 PM
CTD_Neil
12-01-2004 11:25 PM
Ram44maR
09-13-2004 09:59 AM
Quick Reply: injector replacement
