injector install copper washers
so i installed my new injectors without installing new tubes and after talking to a cummins tech he told me this is more then likely my ruff idle and smokey idle and long cranking start up problems. so i bought new crossover tubes and now want to install them but was reading about these copper washers on the bottom of the injectors.. Do i need to get new copper washers again before i install these tubes? or can i just loosen the injector and install the new tubes following the injector install procedure.?
when there out, i torque them to 44inch pounds back off install the tube torque that to 11ft then put the injector down to 89inch pounds then 43ft on the tube...
the tubes have some marks on them and the truck runs ruff and puffs smoke and takes long to start, did this with the old injectors and now with the brand new ones i have in there now. only thing i never changed was the tubes during the installs and there are some marks on the ends and iam making oil.......
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
check the ends of the tubes where they meet the injector. taking them in and out can cause "slight" damage and the sealing surface will not mate up correctly and cause this very problem. clean the surface and reinstall
would low compression have something to do with my starting? the truck only runs like crap and smokes at the first start up of the day. i remeber before when i would plug it in it would always start great...
1985cucv
06-10-2010 06:46 AM
Jason_K
01-13-2009 10:48 PM
hotmopr
07-30-2007 09:02 PM
