Idle noise
Old 01-15-2004 | 04:55 PM
spots's Avatar
Are you back on the road again??
Old 01-15-2004 | 05:07 PM
Haulin_in_Dixie's Avatar
No Paul, got the engine home day before yesterday, spent yesterday getting set up to handle two engines out of the truck, got rain and colder weather coming. I'm outside, no concrete, had to set up another dolly to sit one on and some other preperation stuff. Have about half the work done on pulling the original engine. I work alone in the dirt, goes slower to do it right. I try hard not to do "shade tree" work in the back yard. I have the tools, but not the shop. Trying to get the two engines inside before the rain so I can do the setup stuff on the long block. See I'm not known for working fast, I guess I am half fast
Old 01-15-2004 | 05:14 PM
spots's Avatar
Keep us in the know when you find out what happened to the first engine. Good luck
Old 02-12-2004 | 06:33 PM
Douglas's Avatar
Found this in the TDR web site:
http://www.turbodieselregister.com/...;threadid=81370
my '03 H.O. had the tick at idle since new. it sounded fine at higher rpm's but always came back at idle. I found a cure and it's not pretty. Turns out that the H.O. has a notch in the bottom of the piston on one side to allow clearance for the oil cooling nozzle jet. if a piston is installed with the notch on the wrong side, the piston will lightly tap the oil nozzle on the down stroke and make the tapping noise. This was the case with mine on #5 cylinder. chryslers fix was to replace the short block @ 10,000 mi.. there was no damage to the original block that I could see. after 18 days in the shop the truck is back together and I have put 1,100 miles on the new engine and it runs the way it was designed to.
My 04 has the same tick after starting but seems to go away after warming up. It has been to cold for me to really check tho.
Smkn600CTD
05-22-2012 07:21 PM
ShowMe06
27
01-04-2008 11:47 AM
DF5152
09-16-2003 05:44 PM
Sarge1124
09-01-2003 01:38 PM
DF5152
18
08-28-2003 03:47 PM
Quick Reply: Idle noise
