I have two of the dumbest parts managers ever
Old 11-07-2006 | 12:24 PM
CDoskocil9's Avatar
I called both of my local dodge dealerships for the seals that go on the front and rear differentials of my 2006..... I know their reusable but new ones wouldnt hurt...... Both dealerships tell me their is no seal, and I SHOULD USE RTK sealant........ What gives I know 05's have a reusable seal, do the 06's or am I the dumb one......... Should I use the sealant with the seal if there is one??????????
Old 11-07-2006 | 12:57 PM
ssandlin's Avatar
There is a seal and it is reusable, no extra sealant needed. Just be sure to clean off the seals to ensure there is no debris that could cause a leak.
Old 11-07-2006 | 01:01 PM
CDoskocil9's Avatar
Thanks for the help.......... By the way im going to use royal purple 75w90 anyone have any experience with their product???????
Old 11-07-2006 | 01:11 PM
bnold's Avatar
I use their fluids in my trans and transfer case. Love the stuff. Will put it in the diffs if I ever get around to changing it
Old 11-07-2006 | 01:23 PM
BLACKMAGICDODGE's Avatar
just like in all stuff, ive heard good and ive heard bad(royal purple). Its safe though as far as i can see
Old 11-07-2006 | 01:28 PM
TRAVIST's Avatar
Guys like that make us all look bad!! Here ya go....front gasket 5086682AA
and rear gasket 5086904AB. Hope that helps ya.
Travist
Old 11-07-2006 | 01:40 PM
CDoskocil9's Avatar
Thanks Travist Im going to give them a call with that part number......
Old 11-07-2006 | 03:08 PM
XLR8R's Avatar
Travist
Ditto Travist!
How can some of us be such imbeciles???
It's so hard to find good help these days...
some Techs, Managers, Writers, Advisors, etc. -
Old 11-07-2006 | 10:19 PM
FMB's Avatar
FMB
And do what, reward their stupidity with a parts order?
I'm sure some one else's parts shop would ship you parts.
Old 11-07-2006 | 10:45 PM
cowboy133's Avatar
i'm using RP in both front and rear diffs. The only problem I have is when it is cold I get a little shudder from the rear diff on turns from a stop. Once it is warm though no problems. I am assuming the problem is the limited slip needing the additive that I didn't put in because the manual says not to.
Old 11-07-2006 | 10:56 PM
CDoskocil9's Avatar
Lol no I'm not going to order them anymore, not after they told me they dont have them just wanted to prove them wrong.............The guy at RP told me it has an additive already so shudder shouldnt be a problem but then again he works their.......
Old 11-08-2006 | 12:41 AM
338Lapua's Avatar
Rear Diff.
Cowboy133, I use the RP 75/140 in the rear of my 3500, 5000 miles so far and no problems. Changed it at 3000 miles and cleaned/reused the factory gasket with no leaks or seepage. The limited-slip rear diff. uses helical cut gears that make both axles turn when there is about a 2 to 1 slip ratio similar to a True-Trac, well exactly like one. No clutches or anything that require any special additives.
Old 11-09-2006 | 12:59 AM
BNH4221's Avatar
CDoskocil9 -
FWIW, the 2nd gen trucks did not have a gasket. You used RTV to reseal the diff covers.
The 3rd gens obviously have a gasket. No need for RTV.
Perhaps the parts managers were confused??
Steve
Old 11-09-2006 | 06:41 AM
dogger's Avatar
Gotta wonder
Originally Posted by BNH4221
CDoskocil9 -
Steve
I concerns me that a parts manager would mistake an 06 model for a 2nd generation truck. I guess he could of thought a 96?
L8r,..............dogger
Old 11-09-2006 | 08:26 AM
BNH4221's Avatar
One more reason it pays to know your vehicle.
Steve
PistolWhipt
07-03-2008 01:50 PM
deerefarm06
13
07-29-2007 05:44 PM
upersleder
05-05-2005 11:02 PM
odie2219
08-27-2004 07:01 PM
DawgII
14
02-20-2003 07:14 AM
Quick Reply: I have two of the dumbest parts managers ever
