Hurst Pistol grip shifter
Old 01-07-2010 | 01:14 PM
cminzey's Avatar
I have seen in a few of the Magazines people with the Old style Hurst pistol grip shifter does anyone know who is converting these
Old 01-07-2010 | 01:17 PM
MikeyB's Avatar
The shifter uses 10mm x 1.5 threads so most likely a threaded adapter will be needed.
MikeyB
Old 01-07-2010 | 01:30 PM
cminzey's Avatar
Sorry if this sounds dumb but are they using the pistol grip and welding a nut on the bottom of the shifter do you know who sells these
Old 01-07-2010 | 02:01 PM
.boB's Avatar
The grip has a threaded hole in the bottom that's pretty large. It comes with a few inserts to match the stick. Screw the insert into the hole in the grip, and then screw it onto the shifter.
Many times the grip and adapters don't come anywhere near fitting the stick you have. They want you to buy a whole stick. A little JB works wonders here.
Old 01-07-2010 | 02:12 PM
cmac's Avatar
i got the hurst t-handle shifter for my 96 and the adapters they had in the package matched perfect. the B&M didnt fit though. not sure if they switched all that stuff from 2nd to 3rd gen trucks
Old 01-07-2010 | 02:18 PM
cbrahs's Avatar
CD in NM has a nice billet handle on hers. It was built by a disabled vet. She is going to get me the info so i can get one for mine when I do the tranny swap. I will have her send me a pic and I will post thru photobucket for her.
Old 01-07-2010 | 02:24 PM
wlewis's Avatar
I too am interested in the old Hurst pistol grip shift handles and who might be selling that style. I've seen other pistol grip shift handles with the various threaded adapter inserts but they don't really look like the old school grips from the late 60's and early 70's.
Old 01-07-2010 | 07:07 PM
cminzey's Avatar
that's what I am looking for the retro look from 60s and 70 I have seen them in trucks in the magazines but can't find them
Old 01-07-2010 | 08:44 PM
.boB's Avatar
Like this? http://www.howellautomotive.com/inde...OD&ProdID=1514
Old 01-07-2010 | 08:46 PM
Jim O's Avatar
My Hurst tee handle is from the early 60s and I have had it on at least 8 or 9 different trucks. The Hurst name is starting to show some wear where it is cast into the handle. When I got it it did not have any adapters it was
3/8ths NF and when I got into metric gear shift levers I just drilled and tapped it to the metric size. When I installed my gear vendors I drilled out the end of the tee handle and installed a push button switch to turn the Gear vendors overdrive unit on or off. Once you get used to the Hurst tee handle nothing else is as good.
jmho
JimO
Old 01-07-2010 | 09:41 PM
CD in NM's Avatar
CHRIS - try here - http://www.shiftknobs.us p/n GAG-002-HFS
CD
Old 01-07-2010 | 09:56 PM
cbrahs's Avatar
CD is that where you got yours? I could have sworn we talked about a vet making yours? Maybe I am getting Alzheimers
Old 01-07-2010 | 10:05 PM
dodchall70's Avatar
Try Year One for the original pistol grip.http://www.yearone.com/serverfiles/f...grip&SM=1&SC=1
Or:
CD in NM's Avatar
I got mine froma guy in PA, this is the same handle I have, just not sure if this is where I got it, but this place is in PA and the amount is what I paid. I can't find my receipt, too long ago, tucked away in tax stuff from 2006 or 2007 ????
I spoke with the fellow on the phone, asked about the threading. I am not sure, but I think he was a vet from the more recent ME stuff ???
CD
Old 01-07-2010 | 10:07 PM
CD in NM's Avatar
dodchall70 -
Now that's a NICE pistol grip !!!!!!!!!
CD
