How much hp can stock trans. take
How much horse power can my stock transmission take before it goes. It's a 6 speed on a 03. Don't want to start doing all these mods and find out I needed a stronger transmission.
Wouldnt worry about the transmission, the stock clutch will be the first thing to go.... only mod I had was a smarty on level 5 lasted one sled pull and it was cooked!(66,000 miles)
If you don't lug the motor (below 1500rpm) the go full throttle, I'd say you are safe with a Smarty on medium settings.
Drop the rpm below 1500 then give it full throttle and that clutch will slip easily especially if you are towing.
I would hold on to the 5" exhaust and get a good clutch, approx $ 750
I don't know much about the NV5600 6 Speed. I had an 2005.5 with the g-56I just sold. I had a dual disc valair clutch in it and I was pushing alittle over 500 hp. Never had a problem at all.
HP and Torque levels are not really the deciding facters. It's use. One or two sled pulls, or half a dozen drag strip runs and it's done. Hook it up to 15K# and drive across the Rockies a few times will really beat it up. But it will last for years on the street if driven right.
Thanks for the replies. Shure am glad I always drive sticks. Been reading about guys having automatics and being told that 60 extra hp was all they would take.
Katmandu
15
03-27-2008 04:19 AM
CDoskocil9
11-01-2006 08:14 PM
John Rodriguez
29
08-02-2005 09:24 PM
PThree
17
02-19-2005 10:53 PM
