how many quarts for fluid & filter change - automatic
45k on the 06, no heavy towing.
and it seems to hold each gear a few MPH longer than it used to.
it's under warranty, and they could drop the pan to do a clean & inspect,
but i think i would rather look at it myself.
but i don't know how to adjust the first gear band, might have them do it & adjust the bands during the clean & inspect
i have 12 quarts so far,
advance says 14 qts, 15qts, or 17qts, depending on which line you read
If it is just a pan, filter and gravity drain then 7 to 8 quarts.
If you blow out the cooler line then you can add 5 or 6 more.
Best option is to catch and measure what you drain.
jbham
41
03-01-2019 06:37 PM
fatpete
11-11-2010 05:55 AM
jwb600
13
06-17-2008 08:35 PM
Common
04-07-2008 08:30 AM
