How many guys running a C rated tire
Old 08-19-2013 | 02:07 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I agree with the others....no "C" rated shoes on my trucks...Factory uses "E" rated for a reason and believe me they put the cheapest stuff they can get away with to begin with!!!
They know anything less than a "E" rating will cost them millions in lawsuits
Old 08-20-2013 | 10:05 AM
railroaderone's Avatar
I run a tire shop for my brother and I've had a couple different people put four ply tires on there Cummings powered Rams. They have all stated that they only get about 20k on the front tires. I won't try it because of the weight and possibility of a law suit if something were to happen. Just my 2 cents worth
Old 08-20-2013 | 01:01 PM
gcssr's Avatar
there are a few, some are in the cemetary along with wife and children, but they saved a few bucks
Old 08-20-2013 | 10:18 PM
rockcrawler304's Avatar
Originally Posted by Shorts
That is what I was picturing, a front tire blow out at highway speed won't be pretty under a 4k lb front.
My exact first thought!
Discount Tire has gotten my money.
Same here for about 22 years now!! Not one issue EVER with them.
Originally Posted by johnh
especially with a backhoe in tow
One other thing to remember, your valve stems. Most of these places forget that valve stems have pressure ratings just like the tires do. DO NOT drive away with a full rubber valve stem in place. The correct one is brass and rubber, with the brass piece being about 1/2 inch long. The next, and best option, is a bolt in stem.
THIS!!!
Originally Posted by gcssr
there are a few, some are in the cemetery along with wife and children, but they saved a few bucks
THIS TOO!! Not worth a few dollars. (If they only charged for the C rated tires)
Old 08-21-2013 | 07:19 AM
dezeldog's Avatar
I just don't get it. You spend $40k-$50k for a truck that you call "my baby" and then you talk about putting drain oil in the fuel tank and C rated tires on her just to save a couple bucks. What am I missing here??
Jim
Old 08-21-2013 | 04:26 PM
john40's Avatar
This a good point. Years ago I had Costco install Michelin E rated tires on my '98. The genius who installed them replaced my valve stems with the all rubber type that are rated for 50 psi. In my negligence, I didn't notice this. Months later, while towing our 12,000 # 5th wheel near Barstow, Ca. in 95 degree heat I thought I had a blowout. It was just a valve stem exiting the rim at a high rate of speed. Since then, when buying tires, I check to see if they installed the HD valve stems.
John
Metal Twister
20
10-15-2013 01:52 PM
Hodge
27
09-27-2009 08:21 PM
winkdemon
ABDTR #5
09-18-2008 01:16 PM
MajikMD
58
08-25-2008 04:40 PM
buddy26
47
01-04-2007 08:25 PM
Quick Reply: How many guys running a C rated tire
