How loud does your truck get with cold weather?
Old 01-30-2008 | 09:06 PM
cazman's Avatar
Is it just me or do these truck get MUCH louder when the temp goes down. Its about 20 degrees here and the noise is very noticeable.
Old 01-31-2008 | 06:16 AM
wireman's Avatar
sometimes mine sounds like its going to fly apart when very cold. i take it real easy till it warms up and never over 2k rpm
Old 01-31-2008 | 10:54 AM
DBLR's Avatar
Normal thing with 15w40 oil.
Old 01-31-2008 | 01:29 PM
dodchall70's Avatar
I agree. Mine sounds like it is falling apart.
Old 01-31-2008 | 05:22 PM
cazman's Avatar
Are you saying that different oil will change the sound?
Old 01-31-2008 | 09:05 PM
6 Shaker's Avatar
My truck especially the power steering pump and alternator hate the start up part especially when its -40*F or colder like I've had the last couple of nights here at work. My buddy has a Toyota Sequoia that whines just as loud as my truck when its that cold out. Every other Cummins I've owned sounded that same way so I think it is normal...
P.S. This is with 0W40 synthetic oil, and the rest of the truck is louder and the ride quality is a lot worse.
Old 01-31-2008 | 11:23 PM
billie's Avatar
This is square wheel weather. You should hop in my mustang, it's like riding a goat (not that I've ever actually ridden a goat ) until you round out the tires again.
You really see the extra load from cold in that car. Steering wheel is tight, tranny whines, feels like the p-brake is on when you shift. Makes you appreciate how much that big black Dodge is working extra.
Cya
Old 02-01-2008 | 04:34 AM
TexasCTD's Avatar
It doesn't really get all the cold here in North Texas......20s maybe. But I can tell a huge difference in the way my truck starts up going from 15w40 Rotella to 5w40 Synthetic Rotella. Cranks and runs very smooth. Might be a different story at 20 below though.....
Old 02-01-2008 | 10:18 PM
D-Roc's Avatar
Surely it can't get that cold in Stony Plain...
Old 02-01-2008 | 10:41 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
i noticed when its north texas cold out 20*, my truck chatters like a 6.(point) slow liter powerjoke
Old 02-02-2008 | 09:57 AM
DBLR's Avatar
At those temps you may want to switch your power steering fluid to Amsoil AFT+4 as it has a pour point of -63 F below zero. With a pour point of -63 F below zero, I'm guess its flow point should be around -40 F below zero and that should make your power steering pump happy.
Old 02-02-2008 | 11:07 AM
6 Shaker's Avatar
D-Roc,
It sure does in Ft. McMurray where I work. So cold that the plant where I work has issues staying running with freezing instrumentation and such. The mine also has major issues in supply the bitumen to the upgrader.
Bad Ramer Jamer
12-20-2005 09:16 PM
99 cummins
12-15-2005 10:13 PM
joel
01-22-2005 08:59 PM
wings
11-08-2004 05:32 PM
AFMSgt
22
01-10-2003 12:48 PM
Quick Reply: How loud does your truck get with cold weather?
