How to keep rear axle from leaking after oil change
The last time i changed the differential fluid on my 01, the seal wasn't good enough and there was oil weeping at the bottom.
I have some Amsoil and would like to change it but am worried this too will leak.
The last time I used blue Permatex and ran a bead around the bolt holes then another bead 1/8" lower. I read to let it dry for 30 minutes, then assemble the cover. Maybe that's where I went wrong. Maybe I should have assembled it wet?
How do you guys do it?
When I had my '99 and changed out the diffs I used the blue permatex also. I didn't run beads of it though. Well, I did run beads, but I smoothed them out with my finger all the way around. I then let it set and put the covers back on. I also cleaned/scraped off the metal surfaces on the diff and cover and then acetoned where the permatex would be. No leaks for me!!! Hope this helps!
The way I did it, was I let the sealant set for about ten minutes, then installed it. I also scrubbed the surfaces and cleaned them with a solvent. No Leaky here either.
J
Just so I am straight on this (because I will be going synthetic soon):
To change the rear diff. fluid; you remove the cover, let the fluid drain out, clean and reinstall the gasket, reinstall the cover, add new fluid, and then walk away happy.
You got it!
I like to spray around in the diff with brake cleaner which will evaporate real quickly. And, for bling....you could add a Mag Hytec rear diff cover with an O-ring to seal and get rid of the stock pan and rubber gasket.
I did my first change with no problems, using a torque wrench to make sure not to get them overtightened, and since everything went fine I figured I would never have a problem.
The second time I changed, though, one of the bolts broke off, and it never got close to reaching the specified torque before it snapped.
The book specifies 24 ft/lbs fill plug, and 30 for cover bolts, but next time I think I will go like 25 on the cover bolts so I can leave my easy-out set in the tool box...
I would guess until it crumbles or cracks, which I would guess would be a bunch of uses.
I think most of the dealers just suck the old oil out, but I kind of like to eyeball the contact pattern and so forth as long as I'm messing with it.
Not that I'm a fan of throwing money away, just to be able to change gear oil....
There have been a few threads about Mag Hytec or PML diff covers. 3 advantages to the Mag-Hytec covers:
1) If you fill to the middle of the dipstick range, you will have oil down the axle tube, with more oil lubricating the bearings and seals.
2) You have a disptick to check oil level
3) All surfaces (even the diff face) are o-ringed; NO SEALANT used or required!
The most important:
4) Maintenance is a BREEZE...I can change gear oil in about the same time it takes to change the engine oil!
I have personal experience with the Mag-Hytec covers: They are great in every way. I have no experience withthe PML covers.
HTH
Tony
The most important:
HTH
Tony
how many miles are you guys racking up to change the oil so regularly? I have never done it once and I have 56k miles in only 18 months of ownership. Should this be something I really need to tend to?
Jon
