How to find tdc
Logan...
There is only one way to find TDC on any engine and be precise. The problem is that when the piston is at TDC the crank is still rotating and the piston is not moving, so indicators do not work. I have used the following method for more years than I hate to admit and it is the only real way to be exact or nearly so.
You will need a degree wheel mounted to the front of the crank with a pointer. Remove #1 injector or glow plug, something that will give you a threaded hole into the top of the cylinder. With a bolt or stop threaded into the hole deep enough to contact the piston, rotate the crank by hand very slowly until you feel the piston make very light contact on the inserted stop.
Read the degree wheel, maybe even loosen and rotate so the pointer is on zero. Now, rotate the crank by hand slowly in the opposite direction until you feel the piston gently bump the stop. Look at the degree wheel. If you set it on zero and then rotated it the opposite direction and it stopped on 15 degrees, split the difference in two (7 1/2 degrees) and that is your actual TDC. Make sure that you are doing this on the compression stroke
I hope this is what you were looking for. Good luck
I just use the TDC mark on the damper.
If you can feel open lash on the #1 intake and #1 exhaust then the motor is @ TDC. If you have the TDC mark on the crank in the TDC location and both of the valves listed above are in compressed positions then the engine is @ 180* out.
This method works.....
this method will work on any motor. including two stroke chainsaws with no TDC markings.
Logan...
92smokin blacky
03-10-2011 09:30 AM
05Supersomker
12-19-2007 09:34 PM
1980240D
11-25-2007 10:57 AM
1320
04-27-2004 11:53 AM
