How to enable fast idle 600 motor
Does anyone have the TSB/ Process on how to enable fast idle using cruise control. My dealer does not know and is researching himself. I am having TSB 037 done and want to get this done at the same time.
It is super easy. I had it done yesterday along with the flash (18-037-04).
If they follow the instructions for the High Idle TSB (can't remember # - easily found on this site by searching), all they have to do is enable it.
It works awesome.
It works awesome.
The TSB # is: 18-004-04. If you have the mileage flash, you have the latest software. If you have the 04.5, w/o flash, you can still enable it. You just look at the instructions on the 18-004-04 TSB - and skip the re-programming software part - and follow them it will work. I watched the guy do it, and he just selected "ENABLE" under the appropriate menu.
And to answer the question: when you use the high-idle function (engine temperature has no bearing), it will idle at 1100 RPM, and can be adjusted up to 1500.
Originally posted by Learjockey
I have the list of tsb's but do not find the words "High Idle" in a tsb. I find rough, drone, idle. No high idle.
DO I have to take it to the dealer where I bought my truck to get this stuff done? There is one 15 miles away versus the 80 miles away where I bought the pickup. Should I take off my Air Raid MIT first?
